Fetch succeeds, dies, then deletes file when called from Scheduler??
Hi there,
I’m pulling my hair out over here, hoping you guys can offer some guidance. I’m trying to create a script that, on boot up, will reach out to a remote server, download a “config file” of sorts (or any set of commands) and execute them. In order to achieve this, I’m using a fetch, then calling /import on the file. When I run this script via the CLI, it works perfectly. When I let it execute from the scheduler (on boot), it gets as far as the fetch, the file shows up in the filesystem for a brief second, then vanishes and the script stops there.
What might I be doing wrong here? Is this a bug?
The script:
/system script add name="OnBoot-ConfigFetch" source={/tool fetch url="https://cpe.mydomain.com/routeros/mikrotik-onboot.rsc" mode="https" dst-path="mikrotik-onboot.rsc";/import mikrotik-onboot.rsc;}
/system scheduler add disabled=no name=OnBoot-ConfigFetch on-event=OnBoot-ConfigFetch start-time=startup interval=0s
Running the script with /system script run OnBoot-ConfigFetch works flawlessly. The script does get called successfully via the scheduler, but stops executing after the fetch command.
You could simplify it by calling your file “name.auto.rsc”, in this case it will auto execute:
http://wiki.mikrotik.com/wiki/Manual:Configuration_Management#Automatic_Import
That would only have it run once - I’m trying to ensure that it runs every single time the device boots up.
Also, I am incredibly interested to understand why the behavior of the script / fetch is so negatively affected when run by the scheduler versus being run by hand. That is the bigger concern for me for sure!
bump
I appreciate that the forums are public, and responses may vary.
If nobody is able to comment on this, is there a way for me to pay for support to get an answer?
Or, perhaps someone can suggest another way to achieve what I’m trying to accomplish:
  • We plug in a brand new mikrotik, and either via netinstall or by simply putting a script.auto.rsc file on there, it kicks off a process to call home to us, ask for a config file, download it and apply it
  • On subsequent reboots, or forced script execution, also call home and see if there are any changes (and if so, download + execute)
The first part is totally achievable right now, but because fetch is seemingly dying when used on a scheduler set for “startup”, I cant find a way to have a re-check-in happen after a reboot.
Probably script stops on fetch command because fetch returns some kind of an error.
You can catch that error and proceed with script execution, see example here
http://wiki.mikrotik.com/wiki/Manual:Scripting#Catch_run-time_errors
Yes, but your script can then be simplified. All you need to do is schedule a single fetch. The scrip will be auto-executed and file will be deleted, until next boot.
