Hey guys, are any of you experiencing problems with downloading using “fetch” and saving directly to an SD?
All of my CCR1009’s with a 16GB high-endurance microSD are having problems. Anything over a few hundred kilobytes fails with an incomplete download. fetching to the NAND works perfectly. I thought my SD’s were failing, so I purchased new ones for all of my CCR’s. The new ones are showing the same problem. Formatting ext3 takes about 20~30 minutes.
I can download the file to NAND, and them move it to the SD, however that causes one core to hit 100% and takes up to 30 seconds.
Is anyone else having this issue?
