Fetching system history glitch in winbox
I recently updated my my ccr 2116 into 7.19.6(stable) to 7.20.8 ( long term) after that i have facing issues on displaying system history on my winbox ( v3.43 also in v4.0.1 both) , it didn't appear in first time when i navigate to system history, i have to that and try again navigate to system history then history appears.
BTW in android mikrotik apps it works fine as well as in webfig. Only issue in winbox both v3.43 and v4.0.1.
It there any solution for this , or its a bug , with next update it will be fixed ?? Any idea
I noticed today that I’m having the same problem. I have to open and close the History menu several times until it shows up. This started after updating to 7.20.8. A workaround until they fix this issue is to use the console command: /system/history/print.
