few NETs on ONE interface
Hello everyone.
Could someone answer on one question..
Can i make few NET on ONE interface ?
like: 192.168.1.1 /24
192.168.2.1 /24
192.168.3.1 /24
I think i can’t use VLAN because i don’t have “clever” switches. only simple without terminal.
way from google:
interface aliases..
like: eth0:0
eth0:1
eth0:2
But where it in RouterOS ?
device:CCR1036-12G-4S
Thanks!
I think i found it in
/ip addresses “add new”
That is correct if you simply want multiple subnets serviced by the same interface on the router.
Thanks!
And last problem: :slight_smile:
now i have 2 subnets
192.168.1.0/24
192.168.2.0/24
everything fine but..
If i ping from 192.168.1.10 to 192.168.2.10 ping blocked by windows firewall(windows 7)
can i solve it by router settings ?
maybe common gateway.. or it imposible ?
Thanks!
I have similar setup u should get ping request - except if u have some firewall rules that block traffic in router between two subnets
but do this on 192.168.2.10 pc
Disable windows firewall; Disable Antivirus - Make sure if it is blocked by win7 firewall
or make exceptions in windows firewall settings
