fewi ... need help !!!!
Dear fewi
i need help
hope you can help me
i’m using RB450G with software 5.6
Here TOPOLOGY
i’m using ISP via Fiber Optic connect to L2 Switch. and From L2 Switch have 2 Output Port LAN to my Mikrotik RB450G
from L2 Switch port1 connect to RB450G ether1-Domestic (have up/down 5 Mbps Bandwidth)
from L2 Switch port2 connect to RB450G ether2-Global (have up/down 128 Kbps Bandwidth)
so, i have different Bandwidth came from my ISP and give me 3 IP Public/IP Static
and IP Public already put into ether3-ISP
when i try browsing, is a bit lagging if connection come from ether2-Global
and sometimes i browsing so fast if connection come from ether1-Domestic
when ether3-ISP have no Plug Cable LAN … i’m also can remote into mikrotik RB450G from difference place using IP Static
so, my question is :
  1. can i just only use connection from ether1-Domestic only ??? (coz, i just need Domestic connection for gaming only)
  2. i want share my connection using Access Point to another station (client).
  3. i don’t want give my IP Public to my station (client)
  4. how can i management bandwidth client (limit bandwidth)
  5. is it possible i’m connect using ether5 to be my LAN or share connection to my station (client)
    i’m forget to say. my ISP using Routing BGP with my private AS Number + BGP Peer
and here setting come from my ISP into my Mikrotik RB450G
/ip address print detail
 0   address=192.168.67.94/30 network=192.168.67.92 interface=ether1-Domestic actual-interface=ether1-Domestic
 1   address=192.168.67.154/30 network=192.168.67.152 interface=ether2-Global actual-interface=ether2-Global
 2   address=118.97.xxx.193/29 network=118.97.xxx.192 interface=ether3-ISP actual-interface=ether3-ISP
Here is Routing BGP with AS Number (sorry i hide my AS Number with xxx)
/routing bgp instance print detail
name="default" as=65xxx router-id=0.0.0.0 redistribute-connected=no redistribute-static=no redistribute-rip=no redistribute-ospf=no redistribute-other-bgp=no out-filter="" client-to-client-reflection=yes ignore-as-path-len=no routing-table=""
/routing bgp peer print detail
name="p2p-Domestic" instance=default remote-address=192.168.67.93 remote-as=17xxx tcp-md5-key="" nexthop-choice=default multihop=no route-reflect=no hold-time=3m ttl=default in-filter="" out-filter="" address-families=ip default-originate=never remove-private-as=no as-override=no passive=no use-bfd=no
name="p2p-Global" instance=default remote-address=192.168.67.153 remote-as=17xxx tcp-md5-key="" nexthop-choice=default multihop=no route-reflect=no hold-time=3m ttl=default in-filter="" out-filter="" address-families=ip default-originate=never remove-private-as=no as-override=no passive=no use-bfd=no
/routing bgp network print detail
network=118.97.xxx.192/29 synchronize=yes
/ip dns print
servers: 203.130.193.74,202.134.0.155,203.130.196.5,203.130.206.250
allow-remote-requests: yes
max-udp-packet-size: 512
cache-size: 4096KiB
cache-max-ttl: 1w
cache-used: 9KiB
if i see IP Route … there have 3 original Route after adding “IP Address”
and the other route if i see is come from “BGP Peer ether1-Domestic and ether2-Global”
please help me … i’m not expert from this -_-
and i’m also a noob (newbie)
please teach me step by step
thanks :slight_smile:
here my diagram
yes u restrict bandwidth to clients through queues and u use lan 5 for client
yeah, i’m already done do that
here my code
address=192.168.88.254/24 network=192.168.88.0 interface=ether5-lan actual-interface=ether5-lan
/ip route print detail
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme, B - blackhole, U - unreachable, P - prohibit
dst-address=118.97.xxx.192/29 pref-src=118.97.xxx.193 gateway=ether3-client gateway-status=ether3-client reachable distance=0 scope=10
dst-address=192.168.67.92/30 pref-src=192.168.67.94 gateway=ether1-domestik gateway-status=ether1-domestik reachable distance=0 scope=10
dst-address=192.168.67.152/30 pref-src=192.168.67.154 gateway=ether2-global gateway-status=ether2-global reachable distance=0 scope=10
dst-address=0.0.0.0/0 gateway=118.97.xxx.193 gateway-status=118.97.xxx.193 reachable distance=1 scope=30 target-scope=10
i use computer LAN with IP Address 192.168.88.1 and try Ping to both gateway (192.168.88.254 and 118.97.xxx.193) is already connect
but, when i trying to browsing, i don’t have internet connection
what my problem ???
(before set queue limit bandwidth, i must can connect to internet 1st)
Thanks for reply :slight_smile:
