How do you imagine this automatically ?
MikroTik should create rules for specific resource rapidshare ? In my opinion not all the users will find this option useful (as resources might be different), unless you have the opportunity to create rules with queues and address-list.
Do you have any problems with address-lists and queues configuration (indeed address-list is already automation tool, as you do not need to create multiple mangle/firewall rules to mark all rapidshare data, but just put one rule to mangle and use address-list with rapidshare addresses).
create script, tool that recovers rapdishare ip addresses, and then add them to address-list thats all the automation you need
I just tried this by collecting the ip addresses of the mirrors by d’loading a file.
Here are the ips i got.
195.122.131.88
212.162.63.88
62.67.57.88
207.138.168.88
80.239.151.88
62.67.46.88
64.215.245.88
195.219.1.88
82.129.39.88
80.129.35.88
80.239.236.88
82.129.36.18
80.239.159.18
Now i added this in mangle n marked the conn as rapidshare and all packets as rapidpackets.
Made a simple queue and tried to limit the speeds but it is not working, even tried dropping these packets but its not catching the d’load at all as i dont see any packets increasing in the mangle rule.
What could be the problem?
Kev
read here about mangle:
http://www.mikrotik.com/testdocs/ros/2.9/ip/mangle.php
about queues
http://www.mikrotik.com/testdocs/ros/2.9/root/queue.php
and do not forget that src address list should be used, set protocol tcp port 80
I am using Mikrotik in bridge mode.
Did try setting tcp dest port to 80 , also tried giving the ip pool assigned , no luck.
It just goes thru as before.
address-list is under /ip firewall address-list not /ip pool these are 2 different things
and check wiki, there was example how to limit that if you use bridge
Hi
It should is possible to mark http connections exceeding a certain amount of B and classify it with a low priority in ques. And mark http traffic with low amount of Bytes, as surfing, and put it in front of the ques with a high priority.
Then surfing would be higher priority than http Download. And would work on any server, and any http download, even from “legal” sites. We use it, and it works fine.
Sergejs mentioned it at the top of this tread.
Isn’t this the solution or did I miss anything.?
Best regards
Henrik
Agree with you Normunds. Users are confusing multiple mirror sites with P2P. Yet, for all those who use FileTopia… Have you seen the extensive P2P-like downloads on HTTPS? Several times realized the download goes straight between the clients. That is definitely P2P! And on HTTPS! What now, limit HTTPs? LOL
Thank you Sergej/Janisk,
but what you suggest is what I’ve written at the beginning of this post (if I correctly understood): I’m using MT DNS cache to identify Rapidshare IP addresses and put them into a dedicated access list, let’s call it Rapid_list. Http traffic to/from Rapid_list will be considered as P2P, so P2P queues are applied to this (known process).
At the moment I copy manually these IPs into Rapid_list, what I would like to have is a script that’s able to do this for me, this should be the argument of this post.
No, this traffic will not be considered as P2P, it will be considered as rapidshare traffic, that is being marked with mangle by ‘address-list’ option.
Your argument is clear, the best way to do this, find out all addresses used by rapidshare, create mangle+queues, and create export for this configuration, then copy to all routers.
There is no automated option as far as I know, there is not automatic configuration for this, because other user might want to block/limit another resource.
Thank you sergejs,
yes, it is not P2P, but I “shape” this traffic as it is, in order to limit its download.
This is because I already have a queue for P2P traffic but, once identified, another queue might be created and used specifically for Rapidshare. The problem remains, on how to do this automatically…
I think that the problem is due to the fact that MT does not store DNS cache entries in a file, but simply into its memory. Probably using an external DNS server that stores its entries in a file (better in a mySQL table database) will give better results, because search operation could be done on this file and actions (insert into MT address list) performed by external scheduler (linux chron). Unfortunately I do no have these sw knowledge so I have to look for someone that can do this for me…
cpresto,
here is your script:
:foreach i in=[/ip dns cache find] do={
:if ([:find [/ip dns cache get $i name] "rapidshare"] > 0) do={
:log info ("rapidshare: " . [/ip dns cache get $i name] . " (ip address " . [/ip dns cache get $i address] . ")")
/ip firewall address-list add address=[/ip dns cache get $i address] list=rapidshare disabled=no
Run this regularly using the scheduler, and it will scan the DNS cache of your MikroTik, and add all addresses the have the phrase “rapidshare” in the DNS name to an address-list named “rapidshare”.
As I read your original post, you know how to apply your traffic shaping to addresses in that list, right?
This script will only ADD to the address-list, and as the scripting language does not allow to set a life-time for address-list entries (like you can do from a firewall rule), the addresses will stay there forever (or until manually deleted).
If you want to have a smaller/cleaner/more recent address list, you could add the line
/ip firewall address-list remove [/ip firewall address-list find list=rapidshare]
to the beginning of the script, to clear the address list every time the script is run. Then only hosts which have recently been used (i.e. are in the DNS cache) will be put on the address list.
Does that help?
Best regards,
Christian Meis
Great cmit,
I’ll try and let you know
Thank you,
Carlo
Hi cmit,
script works almost fine: IPs whose name is “xxx.rapidshare.com” are added to the list, while IPs that correspond to “rapidshare.com” are not inserted into the list. Please have a look at addresses here below.
Probably something have to be changed into script search criteria…
[admin@AdiesselleP2K] > ip dns cache print
Flags: S - static
NAME ADDRESS TTL
12 http://www.rapidshare.com 195.122.131.250 8m55s
13 images.rapidshare.com 195.122.131.251 7m7s
14 rs144l3.rapidshare.com 195.122.131.145 8m56s
15 rs178cg.rapidshare.com 82.129.39.179 9m45s
16 rapidshare.com 195.122.131.250 6m44s
17 rapidshare.com 195.122.131.2 6m44s
18 rapidshare.com 195.122.131.3 6m44s
19 rapidshare.com 195.122.131.4 6m44s
20 rapidshare.com 195.122.131.5 6m44s
21 rapidshare.com 195.122.131.6 6m44s
22 rapidshare.com 195.122.131.7 6m43s
23 rapidshare.com 195.122.131.8 6m43s
24 rapidshare.com 195.122.131.9 6m43s
25 rapidshare.com 195.122.131.10 6m43s
26 rapidshare.com 195.122.131.11 6m43s
27 rapidshare.com 195.122.131.12 6m43s
28 rapidshare.com 195.122.131.13 6m43s
29 rapidshare.com 195.122.131.14 6m43s
30 rapidshare.com 195.122.131.15 6m43s
31 rapidshare.com 195.122.131.16 6m43s
32 rapidshare.com 195.122.131.17 6m43s
33 rs148cg.rapidshare.com 82.129.39.149 14m22s
[admin@AdiesselleP2K] ip firewall> address-list
print
Flags: X - disabled, D - dynamic
LIST ADDRESS
53 rapidshare 195.122.131.250
54 rapidshare 195.122.131.251
55 rapidshare 195.122.131.145
56 rapidshare 82.129.39.179
57 rapidshare 82.129.39.149
Rgds
make that “>0” a “>= 0” in the second line and try again…
Best regards,
Christian Meis
Almost done Christian…
it stops when an already inserted entry is found into DNS cache address list, please have a look here below:
Flags: S - static
NAME ADDRESS TTL
55 ns1.rapidshare.com 195.122.131.250 1d19h59m
56 ns2.rapidshare.com 80.237.244.50 1d19h59m
81 rapidshare.com 195.122.131.2 13m10s
82 rapidshare.com 195.122.131.3 13m10s
83 rapidshare.com 195.122.131.4 13m10s
84 rapidshare.com 195.122.131.5 13m10s
85 rapidshare.com 195.122.131.6 13m10s
86 rapidshare.com 195.122.131.7 13m10s
87 rapidshare.com 195.122.131.8 13m10s
88 rapidshare.com 195.122.131.9 13m10s
89 rapidshare.com 195.122.131.10 13m10s
90 rapidshare.com 195.122.131.11 13m10s
91 rapidshare.com 195.122.131.12 13m10s
92 rapidshare.com 195.122.131.13 13m10s
93 rapidshare.com 195.122.131.14 13m10s
94 rapidshare.com 195.122.131.15 13m8s
95 rapidshare.com 195.122.131.250 13m8s
96 rs144cg.rapidshare.com 82.129.39.145 13m8s
97 rs26cg.rapidshare.com 82.129.39.27 13m18s
98 rs91cg.rapidshare.com 82.129.39.92 13m29s
99 rs67cg.rapidshare.com 82.129.39.68 13m50s
100 rs140cg.rapidshare.com 82.129.39.141 13m58s
[admin@AdiesselleP2K] > ip firewall address-list print
LIST ADDRESS
54 rapidshare 80.237.244.50
55 rapidshare 195.122.131.2
56 rapidshare 195.122.131.3
57 rapidshare 195.122.131.4
58 rapidshare 195.122.131.5
59 rapidshare 195.122.131.6
60 rapidshare 195.122.131.7
61 rapidshare 195.122.131.8
62 rapidshare 195.122.131.9
63 rapidshare 195.122.131.10
64 rapidshare 195.122.131.11
65 rapidshare 195.122.131.12
66 rapidshare 195.122.131.13
67 rapidshare 195.122.131.14
68 rapidshare 195.122.131.15
maybe we can add rule checking if the address list contained the same ip from dns cache it will bypass adding ip to addresslist, so next ip will added.
(......add ip rule checking in addresslist here: w/ foreach and if)
(......end of add ip rule checking in addressllist here: w/ foreach and if)
thats my suggestion, CMIIW
that new script doesn´t work, could you repair it, it is good idea to check if ip of searched word isn´t allready in address list and if it is there it won´t be written
Yes,
it should be something similar, new part in red. It doesn’t work, I’m not good enough with scripts …anyone may have a look and correct it?
:if ([:find [/ip dns cache get $i name] “rapidshare”] != 0) do={
address " . [/ip dns cache get $i address] . “)”)
a new for cicle is need to search for already inserted IP address
into rapidshare address list
only new IPs will be added to address list
:foreach f in=[/ip firewall address-list find] do={
:if ([:find [/ip firewall address-list get $f address]] != [:find [/ip
dns cache get $i address]]) do={
replace your red code with this
:if ([/ip firewall address-list get $f address ] != [/ip dns cache get $i address] ) do={
