Fight wireless interference make connection more stable
Hi all,
I have two RB2011UiAS-2HnD configured as AP at the same location (about 5m from each other), both serve about 15 users each. It used to handle quite well all connections but the location has been populated with many AP and the interference is now the main problem. Sometimes it happened that the SSID won’t show at all.
I would really appreciate any help/suggestion to fight the interference and to make the connection more stable, I don’t care about the range it’s ok as it is now. What modification should I do to the current config ?
Thank you in advance,
Below some print screen with the config and spectral scan …
AP 1 uses 2472 frequency and AP 2 uses 2412 frequency
Spectral scan:
AP 1:
AP 2:
Other neighbors AP 1 and 2
