File delete and Hotspot folder replacement after reboot
I’ve noticed a strange behaviour with hEX PoE lite:
  • I put file into the RB with drag and drop function
  • I reboot the RB
  • As the RB returns online, all file is deleted!
  • My custom hotspot folder is replaced with the standard Mikrotik hotspot login page
I tested it with 6.38.5, 6.41.3 and 6.40.7
This device has limit storage on flash, so the files are put in to RAM. You would have to move the files to flash and then point your html_directory in hotspot settings to the files in flash.
