Hi, ive been enjoying The Dude for a long time and this is what i am trying to do.
I want to monitor the number of files in a specific folder.
I want to know if i have mail in the spool folder or undeliverable folder of IIS server.
Id like to show in my Dude map the numbers of files in a specific folder.
ex: c:\inetpub\mailroot\queue…5 files
so i will be able to see if the number goes up like 100 files it means there is a problem with my server.
I will be using this to monitor other server too (coldfusion…) this is not specific to IIS.
Im trying a combination of script to make it happen but no luck yet..
Also is there a way to make the content of a file appear on the appearance of a device ?
Lets say i have a text file with a couple numbers in it…can i GET the content and put it on my map ?
Thanks a lot
This is certainly doable, file counts could be the result of a simple batch job.
Search the forum for execute. Note v4 command works slightly different from v3. Build a very simple example and put it on a label (on the appearance) and go from there.
executes program, returns array of three elements - return code, standard output, standard error. return code is -1 if error occurs. Only first parameter mandatory. First paramerter - command, second - parameters, third - path, forth - input string to pass to program, fifth - timeout in seconds (default 5.0)
NOTE The dude logic is not perfect sometimes -1 is not false when you need -1 to be false add one to it. When building a probe use 0 for error not -1.
For testing put stuff like this on a label, create your own test files… v4.3b examples.
[array_element(execute(“test.bat”,“tests1.txt”,“c:\”),1)]
[execute(“test.bat”,“test.txt”,“c:\”)]
Lebowski
