FILE EXPORT bug
Using 6 rc13 / rc14
If you copy and paste a system script into winbox, it looks fine and it works fine.
But, if you do FILE EXPORT in the terminal, the file it writes has the system script all messed up.
It puts /n/r at the beginning and end of every line of the system scripts, and you cannot import that file!
