file /lib/libexpat.so.1 collides with system package, rb532
Hi
I didn’t find a place to put this, so I’m writing here.
Upgraded my RB532, mipsle, from 3.5 to 3.7, all packages except dude. Then I decided to install dude as well, which I did. When the router rebooted, the first line in the log was:
It seems to work ok, but I don’t know why did it happen, maybe a bug? I don’t know the meaning of it, so I thought to let Mikrotik know.
Best regards
support@mikrotik.com, send supout!
Hi
I never did it, so want to ask about supout. The router didn’t generate a supout file, as it does when it crashes, so if I make a supout file will the relevant information be included there? It happened yesterday and the router worked fine since then.
Best
Instead of posting here, create a supout, give a screenshot of what is happening and send it all to support@mikrtoik.com so that they may be able to recreate the error and/or troubleshoot it.
I had the same problem on a RB333, ROS 3.7, when I added the Dude to the basic package.
Here is the response from MikroTik:
Subject: Re: [Ticket#2008050266000395] ROS 3.7 system warning
Date: May 6, 2008 5:39:29 AM EDT
Hello David,
Thank you for the report.
There is no any problem with that error, it will not be shown in the upcoming
versions.
Regards,
Sergejs
yes, it’s a fake error. it doesn’t cause any problems
