File Shareing Problem useing Hotspot
respected sir, i m faceing file shareing problem kindly suguest me any trouble shoting. here is my diagrame
Server 1 = ISA server 2006 (window server 2003) Ip=192.168.0.1 (DHCP=off) (DNS=on)
Server 2 = File shareing (window server 2003) LAN1 IP=192.168.0.2 (DHCP=off)
LAN2 ip = 192.168.0.2
i was useing the above 2 servers 1 for net and other for shareing since 2 years.
Clients configure there computer by giving menualy a static ip address.
i didnt get any problem. now i have added server 3 on the same network just to test its performance.
Server 3 = Mikrotik os (using Hotspot)
configure as:
LAN=For clients
WAN=for Internet using mikrotik load balancer
addresses list
LAN ip = 192.168.2.1
Wan ip = 192.168.11.1
DNS configured
DHCP configured
then i setup hotspot
everything is working fine. mikrotik working fine. its DHCP properly assigning ip address. and hotspot login worked and internet working fine.
Just faceing an isue with my file shareing. after adding this mikrotik os on my network. my existing clients are faceing isue when they try to open file sharing by putting \server name and sometime it open but after few time it again disapear.
when i remove mikrotik os server. then network again work fine. without any problem.
Can i know why after adding this mikrotik i m getting isue with my fileshareing system??
is there any trouble shooting.??
Regard
faraz Hamza
Bump…
no reply yet
