Is there any way I can allow certain users to utilise Windows File Sharing while connected to my network over PPPoE?
Right now there’s about four people that wish to share files with each other but can’t over PPPoE…
Help!
Help!
say ti them that they use IP address instead of NetBEUI protocol
I do not known why you got such problem?
Your lan used DHCP?
or do not set the fix IP for customers?
if you like share file in your lan
set the same lan for your customer(do not need the gateway)
