Friends, I have the following script:
:local a (“court”);
:local data1 (" at: " elaborate script
by: FRANK MU/OZ") ;
/file print file=$a
/file set $a contents=$data1;
this is invalid:
by: FRANK MU/OZ") ;
elaborate script ???
also put the script inside code blocks
What mean:
“and I want it to save a .TXT file to file” ???
At the end of this:
:local a "court"
:local data1 "do not write random text and call it script"
/file
print file="$a"
the file court.txt is created.
And for do something better, if the file must persist on reboot, this create the file inside flash disk on Flash devices without modifing the script when used on NAND devices.
:local a "court"
:if ([:len [/file find where name="flash" and type="disk"]]=1) do={:set a "flash/$a"}
/file
print file="$a"
