It is possible to load files onto a metarouter? I have tried the drag and drop technique and have also tried to ftp them on with no success.
Thanks!
Chris
Thanks!
Chris
i have not encountered any problems with writing or reading files from RouterOS running as guest on MetaROUTER. Please check if you have not set any disk size limitations in metarouter configuration.
I am using an RB-433, could this be my problem?
Also, would it be possible to run a separate hotspot in the virtual machine? This is where I discovered I could not add the .html files.
Last question, could the virtual hotspot use a virtualAP if it is in a bridge or use it directly?
Thanks,
Chris
no, check your settings, there should not be any problems.
try /metarouter print to see how much your virtual machine use disk space.
also, how much RAM does it use, and how much free RAM you have?
