filter for cache
hello
must we write each filter for realizing the cache or putting “/.” is enough.?
if the last filter is not found, would the filter allows to cache only the extensions of the list, or every extensions even if it was not mentioned in the list.
Every…
Notice that if you don’t cnfigure nothing there, you cache all or you can access all..
Its as: accept all by default.
