Hi Forum
I’ve setting up a system - and can not get the rules for accessing the different network
Headquarter: 192.168.201.0/24
BO1: 192.168.202.0/24
BO2: 192.168.203.0/24
Actually I’m getting the VPN up and running with the IPSEC - following this guide Ipsec Guide
And the VPN are created and talking to each other. I’ve added a route on each Router :
FLAGS DST_ADDRESS PREF_SRC GATEWAY DISTANCE
2 A S 192.168.200.0/21 192.168.201.1 WAN 1 1
Where the preffered source are changing on each router - depending on their local
The Firewall rules I’ve tried without any luck:
Both enabled and disbled NAT rules - does not do any thing
As it is now - I cannot ping between the 2 Routers - neither has I access tp the LAN on the other side of the VPN.
So how should I create these rules for getting access LAN2LAN on this setup
When using pure IPSec, it really doesn’t use the routing table how you are thinking. What happens is the IPSec policy grabs the “interesting traffic”, encrypts it, and then sends the encapsulated traffic to the SA. DST. from the SA. SRC. This traffic then is considered to be originating from the router.
Please include your IPSec settings, that is where the problem is most likely. Just because peers are setup and talking correctly (phase 1) doesn’t mean that the policies are setup correctly.
The same on both sides!
firewall Setup at the moment:
HQ
ip firewall filter print
0 ;;; Allow BO1 access to LAN
chain=forward action=accept src-address=192.168.202.0/24
dst-address=192.168.201.0/24 log=no log-prefix=""
1 ;;; Allow BO2 access to LAN
chain=forward action=accept src-address=192.168.203.0/24
ip firewall nat print
0 ;;; Access FRB
chain=srcnat action=accept src-address=192.168.201.0/24
dst-address=192.168.202.0/24 log=no log-prefix=""
1 ;;; Access FAXE
dst-address=192.168.203.0/24 log=no log-prefix=""
BO1
0 chain=forward action=accept src-address=192.168.201.0/24 dst-address=192.168.202.0/24 log=no log-prefix=""
0 chain=srcnat action=accept src-address=192.168.202.0/24 [size=85][font=Helvetica Neue, Helvetica, Arial, sans-serif]dst-address=192.168.201.0/24 log=no log-prefix="" [/font][/size]
1 ;;; Outgoing Traffik Masquerade
[size=85][font=Helvetica Neue, Helvetica, Arial, sans-serif] chain=srcnat action=masquerade out-interface=WAN log=no log-prefix=""[/font][/size]
I can now ping and access from BO to HQ - but not the other way back.
I can access fileshares and rdp etc and also ping from BO → HQ subnet - But only ping router and not subnet from HQ → BO
I have similar issue - IPSEC tunnel over Internet, Router A pings everything in the Router B private network, but Router B can ping only Router A private address, pinging anything else - not possible. Tried to add routes but with no success. Any ideas?
When in doubt, use IP tunnel with IPsec protection and /30 address on it, then route over that tunnel.
It is much easier to manage in complicated scenarios.
That is why I recommend using an IP tunnel interface with IPsec instead. It is all automatically setup and such
problems are nonexistent. After that, you only need to set a static route at each side, or enable BGP when the
routing is more complicated.
By the way, it began to route the networks, or at least have a ping to all the ip addresses, not just the router…and don’t know why…wrote the rules and it began to work. But I disabled the rules, even restarted router A and still have ping to its network. And new rules are disabled.
pe1chl, can you give a link for this scenario?
Filter:
0 ;;; Allow FRB access to LAN
chain=forward action=accept src-address=192.168.202.0/24 dst-address=192.168.201.0/24 log=no log-prefix=""
NAT:
0 ;;; Access FRB
chain=srcnat action=accept src-address=192.168.201.0/24 dst-address=192.168.202.0/24 log=no log-prefix=""
IPSEC:
> ip ipsec policy print
Flags: T - template, X - disabled, D - dynamic, I - inactive, * - default
0 T * group=*2 src-address=::/0 dst-address=::/0 protocol=all proposal=default template=yes
1 ;;; Policy FRB
src-address=192.168.201.0/24 src-port=any dst-address=192.168.202.0/24 dst-port=any protocol=all action=encrypt level=require ipsec-protocols=esp tunnel=yes sa-src-address=93.161.XX.XX sa-dst-address=78.111.XX.XX proposal=VPN priority=0
> ip ipsec peer print
Flags: X - disabled, D - dynamic
0 X ;;; FRB
address=78.111.XX.XX/32 local-address=:: passive=no port=500 auth-method=pre-shared-key secret="XXXXXXXX" generate-policy=no policy-template-group=default exchange-mode=main send-initial-contact=yes nat-traversal=yes proposal-check=obey
hash-algorithm=sha1 enc-algorithm="" dh-group=modp1024 lifetime=1d lifebytes=0 dpd-interval=2m dpd-maximum-failures=5
> ip ipsec proposal print
Flags: X - disabled, * - default
0 * name="default" auth-algorithms=sha1 enc-algorithms=aes-256-cbc,aes-192-cbc,aes-128-cbc lifetime=30m pfs-group=modp1024
1 name="VPN" auth-algorithms=sha1 enc-algorithms=aes-256-cbc lifetime=30m pfs-group=modp1024
On Location1 Router:
FILTER:
0 ;;; Access to HQ
chain=forward action=accept src-address=192.168.201.0/24 dst-address=192.168.203.0/24 log=no log-prefix=""
NAT:
0 chain=srcnat action=accept src-address=192.168.203.0/24 dst-address=192.168.201.0/24 log=no log-prefix=""
IPSEC:
0 T * group=default src-address=::/0 dst-address=::/0 protocol=all proposal=default template=yes
1 src-address=192.168.203.0/24 src-port=any dst-address=192.168.201.0/24 dst-port=any protocol=all action=encrypt level=require ipsec-protocols=esp tunnel=yes sa-src-address=78.111.XXX.XXX sa-dst-address=93.161.XXX.XXX proposal=VPN priority=0
> ip ipsec peer print
0 ;;; HQ
address=93.161.XXX.XXX/32 local-address=:: passive=no port=500 auth-method=pre-shared-key secret="XXXXXXXXX" generate-policy=no policy-template-group=default exchange-mode=main send-initial-contact=yes nat-traversal=yes proposal-check=obey
hash-algorithm=sha1 enc-algorithm=aes-256 dh-group=modp1024 lifetime=1d lifebytes=0 dpd-interval=2m dpd-maximum-failures=5
What I can:
From HeadQuarter to Location:
Ping the Location router - both from HQ router and local machines
NOT ping the LAN printer accesspoints etc
NOT Access RDP/Filesharing etc from Location LAN
From Location to HeadQuarter:
Ping the HQ router - both from Location router and local machines
Ping the LAN - printers accesspoints etc
access RDP - filesharing etc from HQ LAN
As far as I can see - the settings are the same on both sides, and the rules are set properly.
