Filter port forwarding
there are some ports forwared (dst-nat) from Internet to an internal server.
How can i only allow specific ip address ranges to connect to the internal server from Internet?
For example only devices from IP address ranges 90.111.222.0/24 and 90.200.100.0/24 should be able to connect to the internal Web Server on port tcp 80?
Regards
Hi Cynrik,
The easiest way to do this is to make use of an Address-List, and then dst-nat the traffic inbound from that address list.
Modify the below script as you require.
/ip firewall address-list
add address=90.111.222.0/24 list=Allowed
add address=90.200.100.0/24 list=Allowed
add action=dst-nat chain=dstnat comment="Port Forward" src-address-list="Allowed" dst-port=80 in-interface=ether1 protocol=tcp to-addresses=192.168.1.200
Just remember to change the service port of router! :wink:
 /ip service set port=8080 www
