Filter rule for L2TP (but only from IPsec!)
Hello!
For my Mikrotik L2TP+IPsec server I’ve opened that ports:
  • PROTO 50 ESP,
  • Port 500 UDP (ISAKMP),
  • Port 4500 UDP (NAT-T) and…
I need to accept packets to the L2TP service (1701), but not just any packet: only those that are part of a IPSec SA.
This is the right rule over linux:
iptables -A INPUT -p udp -m policy --dir in --pol ipsec -m udp --dport 1701 -j ACCEPT
Can you help me with Mikrotik syntax instead simple “add chain=eth0 dst-port=1701 protocol=udp” ?
Thanks!
Is not possible?
Thanks again
You can try to improve your suggestion by connection-state=related, but I’m not sure, if it will work with IPsec.
Look at this… http://wiki.mikrotik.com/wiki/Securing_L2TP_Server_for_IPSec
This is the best way to do it.
