Hi community,
I need to add the same filter rule in serveral routers in position 1. Is there a way to add it using the same command?
I know you can create it and then move it, but I want to know if it’s possible to create it in position 1.
Hi community,
The place-before parameter is responsible for this.
ip firewall filter add chain=forward place-before=0
Adds the rule to the first position
NO, is not the right method…
Sometime you have:
/ip firewall filter add chain=forward place-before=0
item referred by ‘place-before’ does not exist (11)
Because that 0 is not valid until you do not print before.
0 is a temporary value.
The right method is, on same line without other commands:
/ip firewall filter add chain=forward place-before=([find]->0)
But both methods do error if no previous rules are presents.
This move last rule on the top:
move ([find]->([:len [find]]-1)) ([find]->0)
But the other problem is if are present some dynamic rules, for example for display fasttrack, better do not move anything before that rules,
then is necessary a check for move the rule before the first static rule
/ip firewall filter add chain=forward place-before=([find where dynamic=no]->0)
the same for move:
move ([find]->([:len [find]]-1)) ([find where dynamic=no]->0)
But, in general, you have to use the utmost precaution, because if you move over “drop everything unclassified”… you cut everything, also your access…
I completely agree with you. Your answer is more extended, I just showed an example of the command.
Works great!
Thanks all!
