filter
I have e problem with my filter in a new mikrotik. in mikrotik 2.8v I had a filter "chain=forward action=drop " that drop all the packet without the listed filter, in a new mikrotik 2.9v these rule’s doesn’t work.
so, if rule is added - it does not count any packets?
what rules are before that one?
if you set it as first rule, what happens then?
the problem is that the rule of drop-in any think else drop all the packet without consider the rule that i have he drop all packet.
post your rules and we will find the error.
[enea@MikroTik] ip firewall filter> print forward
0 ;;; Established connections
chain=forward src-address=0.0.0.0 dst-address=0.0.0.0 protocol=tcp
tcp-flags=!syn connection-state=established action=accept
1 ;;; DNS
chain=forward dst-address=172.16.32.0/28 protocol=udp src-port=53
action=accept
2 ;;; Send SMTP nga Mail
chain=forward src-address=172.16.32.5 protocol=tcp dst-port=25
action=accept
3 ;;; SMTP only MailServer>
chain=forward src-address=172.16.32.0/22 protocol=tcp dst-port=25
action=drop
4 ;;; Serv
chain=forward src-address=172.16.32.0/29 action=accept
5 ;;; 1
chain=forward src-address=172.16.32.11 src-mac-address=00:0A:E4:F5:5D:58
action=accept
6 ;;; 2
chain=forward src-address=172.16.32.12 action=accept
7 ;;; 3
chain=forward src-address=172.16.32.18 protocol=tcp
tcp-flags=syn,!fin,!rst,!psh,!ack,!urg,!ece,!cwr action=accept
8 ;;; SSL
chain=forward src-address=172.16.32.0/23 protocol=tcp dst-port=443
9 ;;; 4
10 ;;; HTTP
chain=forward src-address=172.16.33.0/24 protocol=tcp dst-port=80
action=accept
11 ;;; SMTP connection to Mail server from outside
chain=forward dst-address=172.16.32.5 protocol=tcp dst-port=25
action=accept
12 ;;; FTP connection
chain=forward dst-address=172.16.33.3 protocol=tcp src-port=1023-65535
dst-port=20-21 action=accept
13 ;;; FTP
src-port=1023-65535 dst-port=20-21
14 chain=forward dst-address=172.16.32.0/23 protocol=tcp src-port=20-21
dst-port=1023-65535 action=accept
15 ;;; MSN Messenger
chain=forward src-address=172.16.32.0/23 protocol=tcp dst-port=1863
16 ;;; World Client from outside
chain=forward dst-address=172.16.32.5 protocol=tcp dst-port=80
action=accept
17 chain=forward src-address=172.16.33.3 protocol=tcp src-port=20-21
18 ;;; ICMP
chain=forward src-address=172.16.32.0/23 protocol=icmp icmp-options=8:0
action=accept
19 chain=forward dst-address=172.16.32.0/23 protocol=icmp icmp-options=0:0
action=accept
20 ;;; Drop all that arrive here
this is my filter forwoard
is any body to help me for this case why my filter " chain=forward action=drop " doesn’t work in mikrotik 2.9v
And the counters for your rule #20 don’t increase and the traffic that should be dropped by that rule is actually getting through?
What version of RouterOS 2.9 is that?
Best regards,
Christian Meis
i have checked - at least in 2.9.39 that rules is working correctly
