Filtering incoming requests
Our router does not allow access to IP’s that are outside of our country, does anyone know, how can this be disabled?
The device is mikrotik rb2011uias-2hnd-in.
Create VPN tunnel to a router, that allow this.
Are there any tutorials on how to do that
Just look for web services that allow you to hook your traffic to other country with help of their application, like this https://www.tunnelbear.com/
Link was post not in advertising purpose, but in training. Or just use Tor browser.
(edit)
This wont work, as the requests are made from an apache server used to host websites and I have very limited access to it.
Thats why I was looking for a solution from the router.
If you can manage your Tik, just analyze your firewall, that restrict your access to some global IPs.
Thanks for the help.
The issue was actually caused by the internet provider, the connection was established on port 8989, which happened to be closed.
At the first post, I acually thought it ISP =)
