Hi all,
I want to connect ether1 to ether5 like a bridge so that everything can go about business as usual but i want to add in some filter rules to drop certain traffic.
The device im using is an RB750 and it works 100% when used as a gateway but i see you cant use in and out matcher interface when bridging. Is there another way? I have a few layer 7 filters to kill streaming and content filters mostly to drop a few specific sites.
Lol yeah i get that from using it
Are there any rules that you might recommend in a bridge situation to filter out web address/content?
I would do it any other way but the setup has an Active directory and some pretty fussy software that doesnt play well with the hotspot.
At the moment i have it setup to be either on or off the issue is certain individuals may need unrestricted access ;/
