Filters for +500 prefixes
we need to advertise +500 prefixes to 4 BGP providers.
That means that we need to create 2000 filters?
There is any option to create a address-list? then we will be able to reduce to only 4 filters.
Thanks!
You can use a chain in common for all the upstreams, i.e. ACCEPT-OWN-PREFIXES and then in the 4 separate upstreams chains do a jump.
Cisco, Juniper, Huawei, Alcatel, etc… all have the option to create a “prefix-list” for filters. I’m surprised Mikrotik doesn’t offer this option…
/routing filter ?
what’s your problem?
No option for prefix-list filters
Similar feature is currently in development.
Thanks, something like this is what I expect:
/routing filter add action=accept chain=Upstream-OUT prefix-list=MyPrefix
/routing filter prefix-list
add prefix=1.1.1.0/24 list=MyPrefix
add prefix=2.2.2.0/24 list=MyPrefix
add prefix=3.3.3.0/24 list=MyPrefix
add prefix=4.4.4.0/24 list=MyPrefix
The option to do this is there, you just have to build more than one filter.
First build the prefixes common to multiple peers
/routing filter
add action=accept chain=as-65000-prefixes prefix=203.0.113.0/29 prefix-length=29-32
add action=accept chain=as-65000-prefixes prefix=203.0.113.8/29 prefix-length=29-32
add action=accept chain=as-65000-prefixes prefix=203.0.113.16/29 prefix-length=29-32
add action=accept chain=as-65000-prefixes prefix=203.0.113.24/29 prefix-length=29-32
add action=accept chain=as-65000-prefixes prefix=203.0.113.32/29 prefix-length=29-32
Then build the filter for the peering which references the other filter
/routing filter
add action=accept chain=peering-to-r2-out match-chain=as-65000-prefixes
add action=discard chain=peering-to-r2-out
And finally apply it to the peer in the direction that you want
/routing bgp peer
add name=R2 out-filter=peering-to-r2-out remote-address=100.126.0.2 remote-as=65001
The routes will then be filtered and you can reuse the filter/prefixes on another peer
[admin@R1] > routing bgp advertisements print
PEER     PREFIX               NEXTHOP          AS-PATH                                                              ORIGIN     LOCAL-PREF
R2       203.0.113.32/29      100.126.0.1        incomplete
R2       203.0.113.24/29      100.126.0.1        incomplete
R2       203.0.113.16/29      100.126.0.1        incomplete
R2       203.0.113.8/29       100.126.0.1        incomplete
R2       203.0.113.0/29       100.126.0.1        incomplete
[admin@R1] >
Thanks a lot, I do it and is working very fine.
But, perhaps if instead of adding prefixes as a new filter, they were added in a separate table, it would be more efficient at the CPU consumption level.
The same as the firewall, it is not the same to create 1 rule and 5000 address-list, than to create 5000 rules. In the second case the CPU consumption is much higher.
It definitely would be nice to reference a prefix list directly and MikroTik has stated they are working on it.
However, from a CPU standpoint, Cisco and Juniper do the same thing mostly
Cisco has a route-map that references a prefix list for BGP peers - which requires two different constructs
Juniper has import/export which reference policy-options and that can reference a prefix list - also two different constructs.
If you want your BGP policies to be modular, you need more than one object for efficiency.
