when I open bridge window there is filter tap, how can I put there filters to hide my ap rb from clients side, and how to prevent dhcp ips comming from client’s routers using also filters in the bridge window
In the wiki
Yep I saw that in wiki but there is not general rule that blocks every thing ? In wiki for routers with ips 192.168.0.x do I have to reapet ther rule with other ips like 192.168.1.x and so on because in clients there is diffrent ips in there routers, thanks for your help
General rule that blocks everything is rule without any condition and you need just one for each chain. So they will be three at maximum if you don’t add any custom chain.
I added three rules,
input, forward and output in them same confuguration : drop ,17 (udp) and one option I think I put 800 I dont remember it exactly when I go home I will see it, is this rules right ? I did not put any ips
General drop rule doesn’t contain any condition as it is general. Should be placed last otherwise general accept approach applies.
Sorry I don’t understand it well when I go home I will send pictures of the rules and maybe you can help me, thanks for helping
