FINAL 2 ISP SOLVATION
I have 2 ISP conections one is the frame freay 2M RX/TX with 255 public adress that I wanna to use and other on is DSL 2M RX 256K TX. I need to configure my MT to route all trafic through frame relay conection and spesific incoming ports and protocols (HTTP, FTP,POP3,SMTP,ICMP..ect) through my DSL. I know that is problem for meny and if some one can show ONE example it will solve that problem for others. Best it will be step by step exemple. I try to show how its look`s like:
I will be glad if any one help us. Ofsourse we are talking about MT 2.9 :smiley:
configuration race begin! :wink:
We need the best profesional MT Experts to solve that problem THE PROBLEM FOR MENY PPL. help us and be THE BEST. :slight_smile:
The first one is Tbutcher now.
you can try to hire one of these people:
http://www.mikrotik.com/consultants.html
I hope my solution is working for you, let me know if you need anything else.
Tim
Thx Tbutcher for your help I try to make your canfiguration in near 3 days. If you are abble to contact me my e-mait is butcher24@wp.pl thx again
Butcher
