find command???
can someone enlight me.
if u use some thing like this..
/ip address find address=10.0.20.1
it doesn’t give me any output… not even a 0 => interface number
is this normal? i read the manual. but i just can’t find if it chould output something or if it can only be used in scripts…
this should not give you any output – you have to do something with those addresses, f.e.:
/ip address disable [/ip address find interface=wlan2]
try something like this:
:put [/ip address find address=10.0.20.1]
(don’t forget the colon sign before “put”)
