find command
Hi All
Trying to use a wildcard on find such as:
:put [/ip hotspot ip-binding find comment=check*]
I need to find out any items with the word check in the comment field (check_1) for example
Can it be done? Thanks
It should be possible by the use of regular expressions, e.g.
:put [/ip hotspot ip-binding find comment~"check*"]
Worked a treat - thank you.
thanks +1 i am also searching this a little command for a long
