Hi, like subject…
i’ve already a running script that works fine!
It parse the log to find logged users, but if i add keyword to find “assigned” to, it doesn’t find it!
My code was:
:local currentBuf [ :toarray [ /log find where (message~"logged" || message~"login") ] ]
Then i semplify in this code, actually working:
:local currentBuf [ :toarray [ /log find where (message~"user") ] ]
So, i want to add another keyword, to find new logged devices:
:local currentBuf [ :toarray [ /log find where (message~"user" || message~"assigned") ] ]
but it doesn’t works! Or better, it works but finds only “user” and not find “assigned”.
I try to add topics to, but nothing, it continues to find only “user” keyword:
:local currentBuf [ :toarray [ /log find where (topics~"info" || topics~"dhcp") || (message~"assigned" || "user") ] ]
My scheduler and script have thi permission, and user owner is administrator:
read, write, test
thanks to all.
Jotne
June 6, 2019, 2:53pm
2
To debug what is going on, use :put like this:
Se the code ID
:put [ :toarray [ /log find where (message~"logged" || message~"login") ] ]
To see the messages:
/log print where (message~"logged" || message~"login")
This line:
is the same as
(A or B) or (C or D)
And this is the same as
A or B or C or D
So it will give you all lines with any of the A,B,C or D. Not sure if that is your intention.
Hi, thanks, now i try…
Yes, i only need OR method.
I want only find A or B or C…
I’m not sure to complain :put command.
In the wiki this is not very well explained.
Jotne
June 6, 2019, 7:38pm
4
From Telnet/SSH Cli, tupe :put and then what do.
Eks print all log line that contains lo
:put [ :toarray [ /log find where message~"lo"]
Your OR work, but you can remove some parentheses.
:local currentBuf [ :toarray [ /log find where (topics~"info" || topics~"dhcp" || message~"assigned" || message~"user") ] ]
PS you missed the message in front of user .
So to test your code, try this from command cline (cli)
:put [ :toarray [ /log find where (topics~"info" || topics~"dhcp" || message~"assigned" || message~"user") ] ]
No…
i try :put from command line (ssh session):
:put [ :toarray [ /log find where (message~"assigned" || message~"user") ] ]
but the result is a series of… i don’t know (hex code? other?)
Part of the result:
;*7e4;*7e5;*7e6;*7e7;*7e8;*7e9;*7ea;*7eb;*7ec;*7ed;*7ee;*7ef;*7f0;*7f1;*7f2;*7f3;*7f4;*7f5;*7f6;*7f7;*7f8;*7f9;*7fa;*7fb;*7fc;*7fd;*7fe;*7ff;*800;*801;*802;*803;*804;*805;*806;*807;*808;*809;*80a;*80b;*80c;*80d;*80e;*80f;*810;*811;*812;*813;*814;*815;*816;*817;*818;*819;*81a;*81b;*81c;*81d;*81e;*81f;*820;*821;*822;*823;*824;*825;*826;*827;*828;*829;*82a;*82b;*82c;*82d;*82e;*82f;*830;*831;*832;*833;*834;*835;*836;*837;*838;*839;*83a;*83b;*83c;*83d;*83e;*83f;*840;*841;*842;*843;*844;*845;*846;*847;*848;*849;*84a;*84b;*84c;*84d;*84e;*84f;*850;*851;*852;*853;*854;*855;*856;*857;*858;*859;*85a;*85b;*85c;*85d;*85e;*85f;*860;*861;*862;*863;*864;*865;*866;*867;*868;*869;*86a;*86b;*86c;*86d;*86e;*86f;*870;*871;*872;*873;*874;*875;*876;*877;*878;*879;*87a;*87b;*87c;*87d;*87e;*87f;*880;*881;*882;*883;*884;*885;*886;*887;*888;*889;*88a;*88b;*88c;*88d;*88e;*8.................
In my script i try:
:local currentBuf [ :toarray [ /log find where (message~"assigned" || message~"user") ] ]
it works but find only “user” keyword, nothing “assigned”
Obviously i’m connecting and disonnecting my phone via wifi, and log report correctly assigned and deassigned log.
if i change :local with :put in my script, it doesn’t work anymore.
I try to add a 3rd OR, searching “changed” to:
:local currentBuf [ :toarray [ /log find where (message~"deassigned" || message~"user" || message~"changed") ] ]
but, yet, only “user” appear.
EDIT:
I leaved script saved and working like last version:
so… i leave it only “user” detected…
Now, after about 30 minutes, it detects “changed” keyword to.
Nothing yet about “deassigned” keyword…
Jotne
June 7, 2019, 4:39pm
6
Using find prints the line id that can be used in other part of the script.
Try to replace find with print to get the line.
Hi, “print” seems not function…
or maybe i’m not able, but i’m still trying…
Jotne
June 12, 2019, 3:18pm
8
Post line you try to run.
