This is from ‘MQTT with script scenario’ from here… ‘https://help.mikrotik.com/docs/pages/viewpage.action?pageId=41680915’
The script contains this section…
# Health is a bit iffy since '/system health' does not have 'find' in ROS6
:local health [/system health print as-value]
:local supplyVoltage 0
:local boardTemp 0
:foreach entry in=$health do={
:if ($entry->"name" = "voltage") do={:set $supplyVoltage ($entry->"value")}
:if ($entry->"name" = "board-temperature1") do={:set $boardTemp ($entry->"value")}
I am looking for some clarity on the “Health is a bit iffy since ‘/system health’ does not have ‘find’ in ROS6”. Is this script written to be backwards compatible with ROS6? Can it be improved if being used with ROS7?
Thanks in advance.
