Since I have several gateways (one without routing mark and others with routing marked for routing policy), I need to change them in a script. Using the exact example in docs (below), it changes all my default gateways.
/ip route set [/ip route find dst-address=“0.0.0.0/0”] gateway 10.0.0.1]
How could I select them? I could note the find use the following arguments:
dst-address – Destination address
prefsrc – Source address of packets leaving the router
gateway –
check-gateway – Whether all nexthops of this route are checking reachability of gateway by sending arp requests every 10 seconds
interface – Interface through which the gateway can be reached
gateway-state – Shows the status of the next hop
distance – Administrative distance of the route
scope –
target-scope –
routing-mark – It’s used for policy-routing
from – item numbers
active –
dynamic –
connect –
static –
rip –
bgp –
ospf –
comment – short description of the item
disabled –
I can change the routing marked gateways using
/ip route set [/ip route find dst-address=“0.0.0.0/0” routing-mark=“mark”] gateway 10.0.0.1]
But if I try to change the gateway without routing mark, it doesn’t work. I’ve tried the following without success:
/ip route set [/ip route find dst-address=“0.0.0.0/0” routing-mark=“”] gateway 10.0.0.2]
/ip route set [/ip route find dst-address=“0.0.0.0/0” gateway=“192.168.0.1”] gateway 10.0.0.2]
/ip route set [/ip route find dst-address=“0.0.0.0/0” interface=“ifname”] gateway 10.0.0.2]
How could I solve that? The interface and gateway arguments doesn’t work?
William
