Find the active NAT rule
I have an ipsec tunnel that doesn’t work as the device makes a NAT on the packets.
I can see the next in the log
11:42:56 firewall,info sync: kabel_pass output: in:(none) out:ether7_IPSEC, proto UDP, xxx.xxx.180.187:500->xxx.xxx.191.10:500, NAT (xxx.xxx.180.187:500->xxx.xxx.180.186:500)->xxx.xxx.191.10:500, len 156
I would like to find out why is the source NAT-ed.
Is there a way to find out which rule makes the translation ?
Can it be manipulated in the prerouting phase with mangle ?
It’s the first masq rule. Just create accepting rules above with source and destination networks of you LANs.
Thanks.
It is clear now
