finde and where examples
I'm playing with find and where but I'm missing something.
#works
/ip route print  where dst-address="0.0.0.0/0"
don't work
/ip route find  where dst-address="0.0.0.0/0"
/ip route find  dst-address="0.0.0.0/0"
Aim is to search for comments by using wildcards.
Do I miss something?
Use find command to make an action, like:
/ip route set [find dst-address=0.0.0.0/0] distance=250
Above, you’ll set distance 250 to static routes with dst-address 0.0.0.0/0.
To search, you’re right with:
And if you want to add more parameters, you may use “and”:
/ip route print where dst-address="0.0.0.0/0" and comment="static-route-1"
@Pietro thank you for help.
find
is there a way to test find output on CLI before you start changing something or using in script?
Just to check if your query is right.
where and regex
I have tried to use regex but it looks id doesn't work or I'm missing something.
work
/ip route print where comment="location1-server1"
don't work
/ip route print where comment="location1-.*"
but I have found this and it works
1. /ip route print where comment~"location1"
2. /ip route print where comment~"location1" = false  - list all except what contain location1
3. /ip route print where comment~"location1" = true  - same as 1.
Regards,
Darko Bazulj
