Finding WAN interface name
Hi
I am struggling with RouterOS command line.
I do need to get the interface name of the Wan if.
This commands shows it: ether1-Wan
:put [/ip route check 8.8.8.8]
     status: ok
  interface: ether1-Wan
    nexthop: 92.xxx.xxx.1
This do show all info:
/ip route print
I am thinking of getting the line like this:
:put [ /ip route get [ /ip route find where dst-address=0.0.0.0/0 ]]
and then find the if by using the IP for 0.0.0.0
does this help you?
:put [/ip arp get number=[find where address=[/ip route get number=[find where dst-address="0.0.0.0/0" && active=yes ] gateway]] interface]
:smiley: Do not struggling with RouterOS command line. :smiley:
:put ([/ip route check 8.8.8.8 as-value once]->"interface")
best regards
Perfect :slight_smile:
