Firewal drop rule does not work in local network
I need to block all LAN traffic to to device that have IP address 192.168.88.48. Now I have my firewall rule declared as this:
chain=forward action=drop dst-address=192.168.88.48
Now from my computer located in this network i’m doing curl 192.168.88.48:6969 I’m getting normal response. Nothing is blocked.
My whole firewall config is following:
 0  D ;;; special dummy rule to show fasttrack counters
      chain=forward
 1    chain=forward action=drop dst-address=192.168.88.48 log=no
      log-prefix=""
 2    chain=input action=accept protocol=gre log=no log-prefix=""
 3    chain=output action=accept protocol=gre log=no log-prefix=""
 4    chain=input action=accept protocol=tcp dst-port=1723 log=no
      log-prefix=""
 5    chain=input action=accept protocol=udp dst-port=500 log=no
      log-prefix=""
 6    ;;; default configuration
      chain=input action=accept connection-state=established,related
 7    ;;; default configuration
      chain=input action=accept protocol=icmp log=no log-prefix=""
 8    ;;; default configuration
I also set bridge setting to:
 use-ip-firewall: yes
How can I fix this?
There is special bridge firewall. Have you set the rules there?
You mean /interface bridge filter? I need to have those rules in both places? use-ip-firewall is not enough?
Need more information on your setup. Are you actually using Bridging, or are you Routing?
How can I check it?
Traffic within the local network never passes through routing (forward) filter chains.
It may pass through a bridge, that depends on how you configure the router.
To make this work you need to put that single system on a separate ethernet port of your router
(not behind a switch shared with other users), then you take that ethernet port out of the switch config (remove the
master-port setting), and put that port in a bridge.
Then you can filter in that bridge.
