I’ve implemented firewall based on - Dmitry on firewalling, with few minor adaptations and changes.
http://wiki.mikrotik.com/wiki/Dmitry_on_firewalling
Customer changed mail server (web hosted) and couldn’t receive mails. POP3 protocol. I’ve found out that packed were dropped on the rule that prevents RST attacks:
add chain=sanity-check protocol=tcp tcp-flags=rst action=jump jump-target=drop comment="Drop TCP RST"
This is entry in the log:
firewall,info Drop TCP RST sanity-check: in:LAN(eth1) out:WAN(eth5), proto TCP (ACK,RST), xxxx.xxxx.xxx.xxxx:50373->xxxx.xxxx.xxxx.xxx:110, len 40
So ACK and RST flags were set in the packet and this rule in sanity check drops every packet with set RST flag.
So I changed the rule like this
add action=jump chain=sanity-check comment="Drop TCP RST" jump-target=drop \
port=!110 protocol=tcp tcp-flags=rst
So now the rule drops packets with RST flag set, but not for packets with tcp port 110.
Is this OK or the network is now more vunerable? Should I do things differently?
