I started using the documentation to build my own firewall: https://help.mikrotik.com/docs/display/ROS/Building+Advanced+Firewall
However, first, it does not include rules to allow traffic (probably for simplicity due to NAT) and second, I don’t understand why the last rule is not a DROP all:
add action=accept chain=forward comment="defconf: accept all that matches IPSec policy" ipsec-policy=in,ipsec disabled=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=drop chain=forward src-address-list=no_forward_ipv4 comment="defconf: drop bad forward IPs"
add action=drop chain=forward dst-address-list=no_forward_ipv4 comment="defconf: drop bad forward IPs"
Why do we needs the last four DROP rules if we could just have a single DROP all? Am I missing specific packets?
I have modified my rules like below which I believe is much more compact and elegant:
"PortFW: Complex port forwardings which can’t be fasttracked.” \
connection-mark=conn_portfw connection-state=established,related
add action=jump chain=forward comment="Traffic rules for new connections" \
connection-state=new jump-target=traffic_rules
add action=drop chain=forward comment="Drop everything else (fallback)"
add action=accept chain=traffic_rules comment="Allow from ISP only when DNAT" connection-nat-state=dstnat in-interface-list=ISP
add action=accept chain=traffic_rules comment="Internet for LAN" in-interface-list=LAN out-interface-list=ISP
add action=accept chain=traffic_rules comment="Allow ZoneA --> ZoneB access" in-interface-list=ZoneA out-interface-list=ZoneB
add action=drop chain=traffic_rules comment="Drop everything else"
I first mark existing connections with fasttrak and then accept all existing and untracked connections (same as in the documentation). Then I have a chain “traffic_rules” which only applies to new connections and lists allowed traffic flow in a compact way. Lastly, I just have a DROP ALL rule.
Is there anything wrong this my approach? If not, what is the reason for the more complicated approach in the Mikrotik documentation?
