Hi there
I’m trying to setup ipsec to different networks with my RB4011iGS+ with FW 7.9.1
The destination networks are edge router products.
I can see that the tunnels are established and I am able to ping from the site where the mikrotik is installed, but not the other way.
And I am a bit at a loss as to why?
The plan is to allow all traffic between the ipsec networks: 10.10.10.0/24, 10.10.20.0/24, 10.0.1.0/24 and 10.0.2.0/24
The guides I have seen and read typically no firewall rules are created as a part of the setup, only the NAT rule…
So my guess it that my firewall rules is blocking some traffic towards the 10.10.10.0/24 network.
Is there a way to see packages blocked? ie. from specific sources which may help me figure out where this is blocked…
(and yes I am aware that the ipsec setup isn’t very secure… this will all change later)
Below is the ipsec config, I connect to two sites, one of which has two networks…
/ip ipsec profile
add dh-group=modp2048 enc-algorithm=aes-128 name=xxx1
add dh-group=modp2048 enc-algorithm=aes-128 name=xxx2
/ip ipsec peer
add address=1.1.1.1/32 name=xxx1 profile=xxx1
add address=2.2.2.2/32 name=xxx2 profile=xxx2
/ip ipsec proposal
add enc-algorithms=aes-128-cbc name=proposal1 pfs-group=modp2048
/ip ipsec identity
add peer=xxx1
add peer=xxx2
/ip ipsec policy
add dst-address=10.10.20.0/24 peer=xxx1 proposal=proposal1 src-address=
10.10.10.0/24 tunnel=yes
add dst-address=10.0.1.0/24 peer=xxx2 proposal=proposal1 src-address=
add dst-address=10.0.2.0/24 peer=xxx2 proposal=proposal1 src-address=
Firewall stuff…
add action=masquerade chain=srcnat comment=“defconf: masquerade”
add action=accept chain=input comment=“defconf: accept established,related,untracked” connection-state=
add action=drop chain=input comment=“defconf: drop invalid” connection-state=invalid
add action=accept chain=input comment=“defconf: accept ICMP” protocol=icmp
add action=accept chain=input comment=“defconf: accept to local loopback (for CAPsMAN)” dst-address=127.0.0.1
add action=drop chain=input comment=“defconf: drop all not coming from LAN” in-interface-list=!LAN
add action=accept chain=forward comment=“defconf: accept in ipsec policy” ipsec-policy=in,ipsec
add action=accept chain=forward comment=“defconf: accept out ipsec policy” ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment=“defconf: fasttrack” connection-state=established,related hw-offload=
yes
add action=accept chain=forward comment=“defconf: accept established,related, untracked” connection-state=
add action=drop chain=forward comment=“defconf: drop invalid” connection-state=invalid
add action=drop chain=forward comment=“defconf: drop all from WAN not DSTNATed” connection-nat-state=!dstnat
Any ideas is very welcome…
