Firewall BUG ???
after some days in operation, the counters in the firewall starts to act funny.
On the input-rules, any change results in VERY large numbers.
The forward-rules simply stops counting.
You can se an example of stopped forward rules on demo2.mt.lv - as I can’t make changes, it is not easy to reproduce the input-problem :slight_smile:
Regards
KimC
Could you please be more specific about the problem?
On the demo2.mt.lv router there is no forward traffic that’s why the counters are 0.
As I said, the counters in the forward chain stopped, as there were no traffic (but it is passing 10 Mbps through)
In the input-chain changes to a rule (modify/add) made the counters jump to very high values. After a “Reset All Counters” things looks normal until next change.
The router were passing traffic all the time.
I solved the problem by exporting the rules, deleting them and import again. Now everything looks normal, and the forward rules counts again.
KimC
What version of RouterOS are you using?
i have the same problem here…
the input rules are counting…
the forward rules are not, but seem to work
i did what was sugested by making a .rsc of the forward chain, delete all that was in them and recreated them with the .rsc script.
they are all in there again, but still no counting :frowning:
i upgraded from 2.9RC6 to RC7 but still no change…
any timeline??
Make screenshots and support output file, while something does not work. Send to support@mikrotik.com
i also noticed that logging is not working anymore.
if i select logging to memory.
nothing is in there anymore.
config is still ok…
