Firewall Connection
Hi I have a Telephone machine VOIP under VMware in cloud wich it’s connected to a Mikrotik in the cloud too . There is a L2TP over IP sec Tunnel to another Routerboard wich it’s connected to a VOIP telephones ,
Ever day the 70% of VOIP telephone loosing registration on the telephone machine in the cloud , I have to change the IP addresse of the telephone or to kill the connections marked as Cs in firewall connections ,
Anyone have a solution ??
Thank you
Gesendet von iPhone mit Tapatalk
No one??
Is their a reliance on multicast or broadcasts for this phone system to work? If so you may have to engage something other than L2TP. May need to check with the vendor.
