Firewall connections - limit?
Does the Connections list only show ~2050 entries? GUI shows 2049 out of 76260.
If I filter results, it seems only to search within the visible ones.
The command line only returns visible number also:
:put [:len [/ip firewall connection find]]
2049Where did the rest of them go?
I think it might be a limitation on maximum array size in mikrotik. If it’s really the case, this is an undocumented limitation. Would love to hear from the support about this.
