Firewall connections
How can i log what comes on to the Firewall connections page, i have persistant logs going to a remote syslog server.
Thanks…
Via WebFig:
Simply click on the firewall rule (From menu: IP → Firewall) and near the bottom of the page (after you scroll down) you see the option “Log” - tick the checkbox.
Then, you will see the log in the Log page (if a matching packet has arrived).
Thanks, next question is which of the firewall rules show everything in the connections tab?
…try this; create a rule with action = log with the connection state set to an appropriate value you wish to track
