Firewall Critique/Feedback
I’m working on refining my firewall and would like some feedback on what else I should add. I’ve read a lot of posts and incorporated what I thought was appropriate into the filter list. One thing that I still have to figure out is the foward chain as with the current filter list, if I enable the drop everything else at the end of my forwarding chain, I start dropping a lot of different traffic affecting end users (I can see DNS and other traffic).
I also had a question regarding return statements. Do you need them at the end of a chain that you jumped to or will it automatically return to the originally jump point when it is finishes executing the chain? I wouldn’t think it would return but from my observations, it looks like it does. Thus, the confusion.
I would appreciate any feedback on the following firewall filter list:
0 ;;; Drop Black List IPs
chain=input in-interface=Cloud src-address-list=Black list action=drop
8 ;;; Drop invalid connections
chain=input connection-state=invalid action=drop
9 ;;; Accept related connections
chain=input connection-state=related action=accept
10 ;;; Accept established connections
chain=input connection-state=established action=accept
11 ;;; !!! Check for well-known viruses !!!
chain=input action=jump jump-target=virus
12 ;;; UDP
chain=input protocol=udp action=accept
13 ;;; Allow limited pings 50 over 5 seconds
chain=input protocol=icmp limit=50/5s,2 action=accept
14 ;;; Drop excess Pings
chain=input protocol=icmp action=drop
15 ;;; Allow Winbox connection
chain=input protocol=tcp dst-port=8291 action=accept
16 ;;; TIT1 traffic allowed
chain=input src-address=10.0.0.0/24 action=accept
17 ;;; Home Office traffic allowed
chain=input src-address=192.168.0.0/24 action=accept
18 ;;; Log and drop everything else
chain=input action=log log-prefix=“”
19 X ;;; Log and drop everything else
chain=input action=drop
20 ;;; Drop invalid connections
chain=forward connection-state=invalid action=drop
21 ;;; Established connections
chain=forward connection-state=established action=accept
22 ;;; Related connections
chain=forward connection-state=related action=accept
23 ;;; !!! Check for well-known viruses !!!
chain=forward action=jump jump-target=virus
24 ;;; UDP
chain=forward protocol=udp action=accept
25 ;;; Allow limited pings: 50 over 5 seconds
chain=forward protocol=icmp limit=50/5s,2 action=accept
26 ;;; Drop excess Pings
chain=forward protocol=icmp action=drop
27 X chain=forward action=drop
28 ;;; Drop Blaster Worm
chain=virus protocol=tcp dst-port=135-139 action=drop
29 X ;;; Drop Messenger Worm
chain=virus protocol=udp dst-port=135-139 action=drop
30 ;;; Drop Blaster Worm
chain=virus protocol=tcp dst-port=445 action=drop
31 ;;; Drop Blaster Worm
chain=virus protocol=udp dst-port=445 action=drop
32 ;;; ________
chain=virus protocol=tcp dst-port=593 action=drop
33 ;;; ________
chain=virus protocol=tcp dst-port=1024-1030 action=drop
34 ;;; Drop MyDoom
chain=virus protocol=tcp dst-port=1080 action=drop
35 ;;; ________
chain=virus protocol=tcp dst-port=1214 action=drop
36 ;;; ndm requester
chain=virus protocol=tcp dst-port=1363 action=drop
37 ;;; ndm server
chain=virus protocol=tcp dst-port=1364 action=drop
38 ;;; screen cast
chain=virus protocol=tcp dst-port=1368 action=drop
39 ;;; hromgrafx
chain=virus protocol=tcp dst-port=1373 action=drop
40 ;;; cichlid
chain=virus protocol=tcp dst-port=1377 action=drop
41 ;;; Worm
chain=virus protocol=tcp dst-port=1433-1434 action=drop
42 ;;; Bagle Virus
chain=virus protocol=tcp dst-port=2745 action=drop
43 ;;; Drop Dumaru.Y
chain=virus protocol=tcp dst-port=2283 action=drop
44 ;;; Drop Beagle
chain=virus protocol=tcp dst-port=2535 action=drop
45 ;;; Drop Beagle.C-K
46 ;;; Drop MyDoom
chain=virus protocol=tcp dst-port=3127-3128 action=drop
47 ;;; Drop Backdoor OptixPro
chain=virus protocol=tcp dst-port=3410 action=drop
48 ;;; Worm
chain=virus protocol=tcp dst-port=4444 action=drop
49 ;;; Worm
chain=virus protocol=udp dst-port=4444 action=drop
50 ;;; Drop Sasser
chain=virus protocol=tcp dst-port=5554 action=drop
51 ;;; Drop Beagle.B
chain=virus protocol=tcp dst-port=8866 action=drop
52 ;;; Drop Dabber.A-B
chain=virus protocol=tcp dst-port=9898 action=drop
53 ;;; Drop Dumaru.Y
chain=virus protocol=tcp dst-port=10000 action=drop
54 ;;; Drop MyDoom.B
chain=virus protocol=tcp dst-port=10080 action=drop
55 ;;; Drop NetBus
chain=virus protocol=tcp dst-port=12345 action=drop
56 ;;; Drop Kuang2
chain=virus protocol=tcp dst-port=17300 action=drop
57 ;;; Drop SubSeven
chain=virus protocol=tcp dst-port=27374 action=drop
58 ;;; Drop PhatBot, Agobot, Gaobot
chain=virus protocol=tcp dst-port=65506 action=drop
59 chain=virus action=return
If no match is found in the child chain, the packet will return to the parent chain.
Thanks Eugene. So #59 isn’t needed (I have that disabled anyhow).
I’d appreciate any feedback on the filter as well. I missing some that I need to add but I’m not sure what they are. I’d like to add a drop remaining packets in the forward/input chains but I don’t want to enable that as of yet. Unless someone complains about something not working, I don’t know what else I should add.
I think packet will return anayway even without ‘action=return’. If you want to apply specific action on traffic passed trough ‘virus’ chain, add appropriate action at the end of chain.
Thanks sergejs. Does anyone have any suggestions on what else to add to the forward and input chains?
Seems to be fine. One more example of a good firewall:
http://wiki.mikrotik.com/wiki/Dmitry_on_firewalling
in Dimitry example :
add chain=tcp-services protocol=tcp src-port=1024-65535 dst-port=3128 action=mark-connection new-connection-mark=proxy passthrough=no
if i set the proxy port to 8080 , then the dst-port will be 8080 instead of the default 3128 right ?
right
