thanks for the reply this is the exported rsc
# feb/27/2024 14:49:35 by RouterOS 7.6
# software id =
# model = -=-=
# serial number = --
add name=Switch
set [ find default-name=ether1 ] name=ether1-WAN
/ip hotspot profile
set [ find default=yes ] login-by=cookie,http-chap,https name=HS
/ip hotspot user profile
set [ find default=yes ] shared-users=5
add name=dhcp_pool1 ranges=192.168.86.2-192.168.87.254
add name="up 87.50 below 87.255" ranges=192.168.87.50-192.168.87.254
add name="for A" ranges=192.168.87.51-192.168.87.110
add name="for B, C, D, H, I, J" ranges="192.168.\
87.111-192.168.87.139,192.168.87.141-192.168.87.149,192.168.87.151-192.168\
.87.156,192.168.87.159-192.168.87.160"
add add-arp=yes address-pool="up 87.50 below 87.255" interface=Switch \
lease-time=1h name=DHCP-HS
/ip hotspot
add address-pool="up 87.50 below 87.255" disabled=no interface=Switch \
name=HS
add address-pool="up 87.50 below 87.255" keepalive-timeout=1h name=vip \
rate-limit=4M/4M shared-users=3
/port
set 0 name=serial0
set 1 name=serial1
/ppp profile
add name=vpn-mikhmon
/interface ovpn-client
add connect-to=blabla disabled=yes mac-address=blabla \
mode=ethernet name=ovpn-out1 port=blabla profile=blabla=\
blabla@blabla.net
/queue simple
add max-limit=64k/64k name="Z-Limit" target=192.168.87.161/32
add max-limit=200M/200M name="TOTAL SPEED" queue=default/default target=\
Switch
add comment="A from 87.51 to 87.110" max-limit=15M/15M name=\
"1. A" parent="TOTAL SPEED" queue=\
pcq-upload-default/pcq-download-default target="192.168.87.51/32,192.168.8\
7.52/32,192.168.87.53/32,192.168.87.54/32,192.168.87.55/32,192.168.87.56/3\
2,192.168.87.57/32,192.168.87.58/32,192.168.87.59/32,192.168.87.60/32,192.\
168.87.61/32,192.168.87.62/32,192.168.87.63/32,192.168.87.64/32,192.168.87\
.65/32,192.168.87.66/32,192.168.87.67/32,192.168.87.68/32,192.168.87.69/32\
,192.168.87.70/32,192.168.87.71/32,192.168.87.72/32,192.168.87.73/32,192.1\
68.87.74/32,192.168.87.75/32,192.168.87.76/32,192.168.87.77/32,192.168.87.\
78/32,192.168.87.79/32,192.168.87.80/32,192.168.87.81/32,192.168.87.82/32,\
192.168.87.83/32,192.168.87.84/32,192.168.87.85/32,192.168.87.86/32,192.16\
8.87.87/32,192.168.87.88/32,192.168.87.89/32,192.168.87.90/32,192.168.87.9\
1/32,192.168.87.92/32,192.168.87.93/32,192.168.87.94/32,192.168.87.95/32,1\
92.168.87.96/32,192.168.87.97/32,192.168.87.98/32,192.168.87.99/32,192.168\
.87.100/32,192.168.87.101/32,192.168.87.102/32,192.168.87.103/32,192.168.8\
7.104/32,192.168.87.105/32,192.168.87.106/32,192.168.87.107/32,192.168.87.\
108/32,192.168.87.109/32,192.168.87.110/32"
add comment="B, C, D from 87.111 to 87.160 " max-limit=\
5M/5M name="2. B, C, D, E, F, G" parent=\
"TOTAL SPEED" queue=pcq-upload-default/pcq-download-default target="192.16\
8.87.111/32,192.168.87.112/32,192.168.87.113/32,192.168.87.114/32,192.168.\
87.115/32,192.168.87.116/32,192.168.87.117/32,192.168.87.118/32,192.168.87\
.119/32,192.168.87.120/32,192.168.87.121/32,192.168.87.122/32,192.168.87.1\
23/32,192.168.87.124/32,192.168.87.125/32,192.168.87.126/32,192.168.87.127\
/32,192.168.87.128/32,192.168.87.129/32,192.168.87.130/32,192.168.87.131/3\
2,192.168.87.132/32,192.168.87.133/32,192.168.87.134/32,192.168.87.135/32,\
192.168.87.136/32,192.168.87.137/32,192.168.87.138/32,192.168.87.139/32,19\
2.168.87.141/32,192.168.87.142/32,192.168.87.143/32,192.168.87.144/32,192.\
168.87.145/32,192.168.87.146/32,192.168.87.147/32,192.168.87.148/32,192.16\
8.87.149/32,192.168.87.151/32,192.168.87.152/32,192.168.87.153/32,192.168.\
87.154/32,192.168.87.155/32,192.168.87.156/32,192.168.87.159/32,192.168.87\
.160/32"
add max-limit=2M/2M name="H" parent="TOTAL SPEED" queue=\
default/default-small target=192.168.87.158/32
add max-limit=2M/2M name="I" parent="TOTAL SPEED" queue=\
default/default target=192.168.87.157/32
add max-limit=2M/2M name="J" parent="TOTAL SPEED" queue=\
default/default target=192.168.87.140/32
add max-limit=2M/2M name="K" parent="TOTAL SPEED" queue=\
default/default target=192.168.87.150/32
add address-pool="A" insert-queue-before="Z-Limit" name=A \
parent-queue="1. A" queue-type=hotspot-default rate-limit=3M/3M \
shared-users=3
add address-pool="B, C, D, E, F, G" \
insert-queue-before="Z-Limit" name=\
"B, C, D, E, F, G" parent-queue=\
"2. B, C, D, E, F, G" queue-type=\
hotspot-default rate-limit=1M/1M shared-users=2
add address-pool="up 87.50 below 87.255" insert-queue-before=\
"Z-limit" keepalive-timeout=1h name=blabla parent-queue="1. A" \
queue-type=hotspot-default rate-limit=5M/5M shared-users=10
insert-queue-before="Z-Limit" name=lalala parent-queue=\
hotspot-default rate-limit=1M/1M shared-users=90
/snmp community
set [ find default=yes ] name=IndosatCmp2024
add bridge=Switch interface=ether2
add bridge=Switch interface=ether3
add bridge=Switch interface=ether4
add bridge=Switch interface=ether5
add bridge=Switch interface=ether6
add bridge=Switch interface=ether7
add bridge=Switch interface=ether8
add bridge=Switch interface=ether9
add bridge=Switch interface=ether10
add bridge=Switch interface=ether11
add bridge=Switch interface=ether12
add bridge=Switch interface=ether13
add bridge=Switch interface=ether14
add bridge=Switch interface=ether15
add bridge=Switch interface=ether16
add bridge=Switch interface=sfp-sfpplus1
add bridge=Switch interface=sfp-sfpplus2
/interface detect-internet
set detect-interface-list=all
add address=192.168.86.1/23 interface=Switch network=192.168.86.0
add address=lala.lala.lala.lala/30 disabled=yes interface=ether1-WAN network=\
lala.lala.lala.lala
add address=lala.lala.lala.lala/28 interface=ether1-WAN network=lala.lala.lala.lala
/ip arp
add address=192.168.87.157 comment="lala" interface=Switch mac-address=\
lala
add address=192.168.87.150 comment="lolo" interface=Switch \
mac-address=lolo
add address=192.168.87.140 comment="lili" interface=Switch \
mac-address=lili
add address=192.168.87.105 comment=lele interface=Switch mac-address=\
lele
add address=192.168.87.234 comment="lulu" interface=\
Switch mac-address=lulu
add address=lalala comment=\
"lblb" interface=ether1-WAN \
mac-address=lblb
add address=192.168.87.158 comment="lclc" interface=Switch \
mac-address=lclc
add address=192.168.87.15 comment=\
"ldld" interface=Switch \
mac-address=ldld
add address=192.168.87.179 comment="lflf" interface=Switch \
mac-address=lflf
add address=192.168.86.3 comment="lglg" \
interface=Switch mac-address=lglg
add address=192.168.87.16 comment="lhlh" interface=\
Switch mac-address=lhlh
add address=192.168.87.254 comment="ljlj" \
interface=Switch mac-address=ljlj
/ip dhcp-server lease
add address=192.168.87.234 client-id=lklk mac-address=\
lklk server=DHCP-HS
add address=192.168.86.3 client-id=llll mac-address=\
llll server=DHCP-HS
add address=192.168.86.0/23 gateway=192.168.86.1
set allow-remote-requests=yes servers=lmlm,lnln
/ip firewall address-list
add address=192.168.86.0/23 list=LAN
add address=lplp list="allowed outside IP to Akses Remote Mikrotik"
add address=192.168.31.1 list="allowed outside IP to Akses Remote Mikrotik"
add address=lqlq/22 list=\
add address=lrlr/27 list=\
add address=192.168.87.111-192.168.87.139 list="test youtube1"
add address=192.168.87.141-192.168.87.149 list="test youtube2"
add address=lsls/30 list="IP mikrotik router wan ISP"
add address=ltlt/28 list="IP mikrotik router wan ISP_"
add action=drop chain=forward content=youtube.com dst-address=lvlv/28 \
src-address=192.168.86.0/23
add action=passthrough chain=unused-hs-chain comment=\
"place hotspot rules here"
add action=accept chain=forward connection-state=established,related \
dst-address=lvlv/28
add action=accept chain=input dst-address=lvlv/28 src-address-list=\
add action=drop chain=forward connection-state=invalid dst-address=\
lvlv/28
add action=drop chain=input connection-state=invalid dst-address=\
lvlv/28
LAN
add action=accept chain=input connection-state=established dst-address=\
lvlv/28
add action=accept chain=forward connection-state=new dst-address=\
lvlv/28 src-address-list=LAN
add action=accept chain=forward connection-state=related dst-address=\
lvlv/28
add action=accept chain=forward connection-state=established dst-address=\
lvlv/28
add action=drop chain=forward dst-address=lvlv/28
"place hotspot rules here" disabled=yes
add action=masquerade chain=srcnat out-interface=ether1-WAN
add action=dst-nat chain=dstnat disabled=yes dst-address=lwlw \
dst-port=81 protocol=tcp to-addresses=192.168.... to-ports=lxlx
add action=src-nat chain=srcnat disabled=yes protocol=tcp src-address=\
192.168.... src-port=lxlx to-addresses=lzlz to-ports=..
/ip hotspot ip-binding
add address=192.168.87.140 comment="lzlz" mac-address=\
lzlz server=HS to-address=192.168.87.140 type=bypassed
add address=192.168.87.105 comment="lzalza=\
lzalza server=HS to-address=192.168.87.105 type=bypassed
add address=192.168.87.... comment="lzblzb" mac-address=lzblzb \
server=HS to-address=192.168.87.... type=bypassed
add address=192.168.87.... comment="lzclzc" mac-address=lzclzc \
add address=192.168.87.150 comment="lzdlzd" mac-address=\
lzdlzd server=HS to-address=192.168.87.150 type=bypassed
add address=192.168.87.5 to-address=192.168.87.5 type=bypassed
add address=192.168.87.3 mac-address=lzelze to-address=\
192.168.87.3 type=bypassed
add address=192.168.87.4 mac-address=lzflzf to-address=\
192.168.87.4 type=bypassed
add address=192.168.87.6 to-address=192.168.87.6 type=bypassed
add address=192.168.86.3 comment=wifi ap disabled=yes mac-address=\
lzglzg server=HS to-address=192.168.86.3 type=bypassed
add address=192.168.87.234 comment=wifi ap2 disabled=yes mac-address=\
lzflzf server=HS to-address=192.168.87.234 type=bypassed
add address=lzhlzh/28 comment="IP mikrotik ISP" type=bypassed
add address=192.168.87.15 comment="lzilzi" \
mac-address=lzilzi to-address=192.168.87.15 type=bypassed
add address=192.168.87.179 comment="Printer" mac-address=\
lzjlzj to-address=192.168.87.179 type=bypassed
add address=192.168.87.16 comment="lzklzk" mac-address=\
lzklzk to-address=192.168.87.16 type=bypassed
add address=192.168.87.254 comment=\
"lzllzl" disabled=yes \
mac-address=lzllzl to-address=192.168.87.254 type=bypassed
/ip hotspot user
add name=AA
add name=BB profile="A, B, C, D, E, F" \
server=HS
add name=CC profile="A, B, C, D, E, F" server=\
HS
add name=DD profile="A, B, C, D, E, F" \
server=HS
add name=EE profile="A, B, C, D, E, F" server=\
HS
add name=FF profile="A, B, C, D, E, F" server=\
HS
add name=GG profile="A, B, C, D, E, F" server=\
HS
add name=HH profile="A, B, C, D, E, F" \
server=HS
add name=II profile="A, B, C, D, E, F" \
server=HS
add name=JJ profile="A, B, C, D, E, F" \
server=HS
add name=KK profile="A, B, C, D, E, F" server=\
HS
add name=LL profile="A, B, C, D, E, F" server=\
HS
add name=MM profile="A, B, C, D, E, F" server=\
HS
add name=NN profile="A, B, C, D, E, F" server=\
HS
add name=OO profile="A, B, C, D, E, F" server=\
HS
add name=PP profile="A, B, C, D, E, F" server=\
HS
add name=QQ profile="A, B, C, D, E, F" \
server=HS
add name=RR profile="A, B, C, D, E, F" server=\
HS
add name=SS profile="A, B, C, D, E, F" server=\
HS
add name=TT profile="A, B, C, D, E, F" server=\
HS
add name=UU profile="A, B, C, D, E, F" server=\
HS
add name=Cool1 profile=lzjlzj server=HS
add name=Cool2 profile=lzjlzj server=HS
add name=Cool3 profile=lzjlzj server=HS
add name=Cool4 profile=lzjlzj server=HS
add name=Cool5 profile=lzjlzj server=HS
add name=Cool6 profile=lzjlzj server=HS
add name=Cool7 profile=lzjlzj server=HS
add name=Cool8 profile=lzjlzj server=HS
add name=Cool9 profile=lzjlzj server=HS
add name=Cool10 profile=lzjlzj server=HS
add name=Cool11 profile=lzjlzj server=HS
add name=Cool12 profile=lzjlzj server=HS
add name=Cool13 profile=lzjlzj server=HS
add name=Cool14 profile=lzjlzj server=HS
add name=Cool15 profile=lzjlzj server=HS
add name=Cool16 profile=lzjlzj server=HS
add name=Cool17 profile=lzjlzj server=HS
add name=Cool18 profile=lzjlzj server=HS
add name=great profile=great server=HS
add name=nice profile=nice server=HS
add name=perfect profile="A, B, C, D, E, F" server=HS
add name=decent profile="A, B, C, D, E, F" \
server=HS
add name=AB profile="A, B, C, D, E, F" \
server=HS
add name=AC profile="A, B, C, D, E, F" \
server=HS
add name=AD profile=\
add name=AE profile="A, B, C, D, E, F" \
server=HS
add name=AF profile="A, B, C, D, E, F" \
server=HS
add name=AG profile="A, B, C, D, E, F" \
server=HS
add name=AH profile="A, B, C, D, E, F" \
server=HS
add name=AI profile="A, B, C, D, E, F" \
server=HS
add name=AJ profile="A, B, C, D, E, F" \
server=HS
add name=AK profile="A, B, C, D, E, F" \
server=HS
add name=AL
add name=AM profile=lzjlzj server=HS
add disabled=yes distance=1 dst-address=0.0.0.0/0 gateway=lala \
pref-src="" routing-table=main scope=30 suppress-hw-offload=no \
target-scope=10
add disabled=yes distance=1 dst-address=lala/30 gateway=192.168.86.1 \
target-scope=10
add check-gateway=ping disabled=no distance=2 dst-address=0.0.0.0/0 gateway=\
lala pref-src="" routing-table=main scope=30 suppress-hw-offload=\
no target-scope=10
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/snmp
set contact="Who who" enabled=yes trap-version=2
/system clock
set time-zone-name=great/great
/system identity
set name=cool-cool
/system logging
add action=disk prefix=-> topics=hotspot,info,debug
/system routerboard settings
set enter-setup-on=delete-key
/tool romon
set enabled=yes
