firewall drop connection
Hi. I have IP POOL range x.x.88.1/24, DHCP x.x.88.25-254. Can I set the firewall to block access to the addresses x.x.88.1-24 from the DHCP range? Or is there another solution? Thank you.
hmmm… 24 is not a nice binary number like 16 or 32 (110000 vs 10000/100000). Using a subnet mask is out then.
You can add those addresses in an address list and use that one in your firewall rule, I would think ?
Address list SERVER_RANGE (or whatever), add all addresses from 192.168.88.1 to 192.168.88.24
And then forward rule to drop everything from 192.168.88.0/24 to dst_address_list SERVER_RANGE
Move on top of forward rule block.
Or … you can even put it as a RAW prerouting rule, should go faster and goes before any normal firewall rule.
If however you can change the range to 32 addresses, you could use 192.168.88.0/27 as criterium in the rule.
Forward drop src_address = 192.168.88.0/24, dst-address = 192.168.88.0/27
Or RAW rule. Same remark, goes before any normal firewall rule and is processed a lot faster.
Maybe easier ?
Make sure your PC has a lower range address before implementing this or you will block yourself !
I’m sure others will come in with more logical and/or brilliant ideas :laughing:
Strange ask but I guess you dont want anyone with access to be able to manually set 1-24
Assuming your IP address is set to 192.168.88.254 interface=bridge network=192.168.88.0
I would create a firewall address list of 192.168.88.25-192.168.88.253 list=ALLOWED
add action=accept chain=input comment=“defconf: accept established,related,untracked” connection-state=established,related,untracked
add action=accept chain=input comment=“defconf: accept ICMP” protocol=icmp
add action=accept chain=input comment=“defconf: accept to local loopback (for CAPsMAN)” dst-address=127.0.0.1
add action=accept chain=input comment=“Allow all LAN” in-interface-list=LAN src-address-list=ALLOWED
add action=drop chain=input comment="drop all else
AND
add action=fasttrack-connection chain=forward connection-state=established,related
add action=accept chain=forward connection-state=established,related,untracked
add action=accept chain=forward comment=“internet traffic” in-interface-list=LAN src-address-list=ALLOWED out-interface-list=WAN
**** add additional allow rules here, admin to all vlans, or all users to shared printer etc. *********
add action=accept chain=forward comment=“port forwarding” connection-nat-state=dstnat
add action=drop chain=forward comment="Drop all else
In this way only, only .25 to .243 will get DNS or internet, in effect blocking any of the other non DHCP pool IPs.
Dont know if this is better or not than raw rules which I tend to avoid if possible probably something like this to be doubly sure!!
I would create a second firewall address list of 192.168.88.1-192.168.88.24 list=VERBOTEN
/ip firewall raw
add chain=raw action=drop src-address-list=VERBOTEN
add chain=raw action=drop dst-address-list=VERBOTEN
That sounds good, I was thinking about this option, I’ll try it.
Thank you.
But with this rule I won’t see from addresses 1-32 to any address 1-32. It will be better to create a list of addresses 33-254 and drop using the rule “forward drop src address list, dst address /27”.
It doesn’t matter if someone wants to manually set IP 1-32 (that can’t happen), only I can do that anyway :smiley: .
You got a point.
You can check for src_address!=192.168.88.0/27, dst_address=192.168.88.0/27
Briliant!
You got a point!
