MT (192.168.1.3) is connected through lan cable into the one port of DSL (192.168.1.1) modem. The wifi AP (192.168.1.2) is connected to the DSL modem as well through Lan cable.
The user is connected to the AP wirelessly.
MT is the only DHCP server of the network and most of the devices are connected to the network through the AP wirelessly.
I can see all the mac addresses but it seems i cant block/handle them
What you could do (although it is not a real solution) is put a bogus IP address as reservation for the deisred MAC address.
If the device then request an IP from the DHCP server it will get a unusable IP address and will not be able to browse the internet. (e.g. assign 192.168.100.254 for the device).
The side note I have to make is that if the user of the device is smart enough, he can put his IP settings manually and the completely bypass the DHCP.
Thats what i thought from the first time but yes if he set his devices ip manually then he can have access. So im looking for a “proper” and permanent solution.
Liodakis thank you for your reply. My mikrotik PC has 1 LAN port (the built-in one) at the moment so im not quite sure how i can run mikrotik as PPPoE ADSL modem router. If im not mistaking you advise me to set the LAN port of mikrotik as WAN and then do the rest from a second LAN port (NAT, local routing etc). So i might be in need to find-buy a 2nd LAN card. Correct?
