Toby7
January 4, 2014, 2:37pm
1
I am currently working on my firewall improvements. There is a PPPoE connection to my ISP. My router is configured as source nat with filter rules. Currently I have only the basic filter rules which are recommended in the book “Router OS by example”.
0 ;;; ###
chain=input action=drop connection-state=invalid
in-interface=PPPoE-TelekomDSL
1 ;;; ###
chain=forward action=drop connection-state=invalid
2 ;;; ###
chain=input action=accept connection-state=established
3 ;;; ###
chain=input action=drop in-interface=PPPoE-TelekomDSL
4 ;;; ###
chain=forward action=accept connection-state=new
src-address-list=Telekom Subnet in-interface=PPPoE-TelekomDSL
5 ;;; ###
chain=forward action=accept connection-state=related
6 ;;; ###
chain=forward action=accept connection-state=established
7 ;;; ###
chain=forward action=drop in-interface=PPPoE-TelekomDSL
To validate my settings nmap is the tool I use. So doing nmap -sT gives my this output:
PORT STATE SERVICE
25/tcp open smtp
80/tcp open http
110/tcp open pop3
119/tcp open nntp
143/tcp open imap
465/tcp open smtps
587/tcp open submission
993/tcp open imaps
995/tcp open pop3s
8080/tcp open http-proxy
Currently I don’t know where any of these open port come from? Can you help please…
Thank you
Toby
Do you have any port forwarding NAT rules?
If no, you may not be scanning the correct IP address. Is “” the address assigned to your PPPoE-TelekomDSL interface or a LAN IP?
Toby7
January 5, 2014, 2:22pm
3
No there are just the firewall → service ports enabled. I thought they should be a kind of nat helper which you better do no disable.
The scan goes toward the local adress of the pppoe client. According to my knowledge this is the WAN IP?
I used android tethering(mobile network) as internet connection for the scan. May this influence something?
In order to do more than guess, I believe we need to see
/interface print
/ip address export
/ip firewall export
/ip firewall print
/ip mangle print
/ip route print
Then tell us the IP address of your nmap machine, the physical port on the MikroTik to which your nmap machine is connected, and the actual IP that you are testing, and run your nmap again. You can replace the first two octets of any public IP address with letters so long as the letters are a one-to-one substitution for the octets they are replacing.
Toby7
January 6, 2014, 11:08pm
5
Here are the exports:
/interface print
NAME TYPE MTU L2MTU MAX-L2MTU MAC-ADDRESS
0 R ether1_fritzbox ether 1500 1598 4074 00:0C:42:C1:F9:9D
1 R ether2_homenet ether 1500 1598 4074 00:0C:42:C1:F9:9E
2 R ether3_telekom ether 1500 1598 4074 00:0C:42:C1:F9:9F
3 R ether4_modem_telekom ether 1500 1598 4074 00:0C:42:C1:F9:A0
4 R ;;; ::: VLAN Trunk :::
ether5_trunk ether 1500 1598 4074 00:0C:42:C1:F9:A1
5 R PPPoE-TelekomDSL pppoe-out 1480
6 R vlan1_ether5 vlan 1500 1594 00:0C:42:C1:F9:A1
7 R vlan100_ether5 vlan 1500 1594 00:0C:42:C1:F9:A1
8 R vlan200_ether5 vlan 1500 1594 00:0C:42:C1:F9:A1
add address=192.168.0.254/24 interface=ether2_homenet network=192.168.0.0
add address=192.168.128.254/24 interface=ether3_telekom network=192.168.128.0
add address=10.0.128.254/24 interface=vlan100_ether5 network=10.0.128.0
add address=10.0.192.254/24 interface=vlan200_ether5 network=10.0.192.0
/ip firewall export
/ip firewall address-list
add address=192.168.128.0/24 list=local-addresses
add address=192.168.0.0/24 list=local-addresses
add address=10.0.192.0/24 list=local-addresses
add address=10.0.128.0/24 list=local-addresses
add address=192.168.128.0/24 list="Telekom Subnet"
add address=192.168.0.0/24 list="E Homenet Subnet"
add address=10.0.192.0/24 list="F PV Subnet"
add address=10.0.128.0/24 list="Guest WLAN Subnet"
add address=192.168.0.119 list=addressList_PenetrationTesting
add address=A.B.C.14 list=addressList_WANIPTelekom
add action=drop chain=input connection-state=invalid
add chain=input connection-state=established in-interface=PPPoE-TelekomDSL
add action=drop chain=input in-interface=PPPoE-TelekomDSL
add chain=forward connection-state=new in-interface=PPPoE-TelekomDSL
src-address-list="Telekom Subnet"
add chain=forward connection-state=related in-interface=PPPoE-TelekomDSL
add chain=forward connection-state=established in-interface=PPPoE-TelekomDSL
add action=drop chain=forward in-interface=PPPoE-TelekomDSL
/ip firewall mangle
add chain=prerouting dst-address-list=local-addresses dst-address-type="" fragment=no
add action=mark-routing chain=prerouting dst-address-list=addressList_WANIPTelekom new-routing-mark=table_PenetrationTesting passthrough=no
src-address-list=addressList_PenetrationTesting
add action=mark-routing chain=prerouting new-routing-mark=WANTelekom passthrough=no
add action=mark-routing chain=prerouting new-routing-mark=fromFPV passthrough=no
src-address-list="F PV Subnet"
fromflyingEGuest passthrough=no src-address-list="Guest WLAN Subnet"
add action=mark-routing chain=prerouting in-interface=PPPoE-TelekomDSL
add action=masquerade chain=srcnat out-interface=PPPoE-TelekomDSL src-address=192.168.128.0/24
192.168.0.0/24
/ip route print
DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 A S 0.0.0.0/0 PPPoE-TelekomDSL 1
1 A S 192.168.0.0/24 ether2_homenet 1
2 A S 192.168.128.0/24 ether3_telekom 1
3 A S 0.0.0.0/0 192.168.179.1 1
4 A S 0.0.0.0/0 192.168.179.1 1
5 A S A.B.C.14/32 192.168.0.240 1
6 A S 0.0.0.0/0 192.168.0.240 1
7 S 0.0.0.0/0 PPPoE-TelekomDSL 5
8 ADC 10.0.128.0/24 10.0.128.254 vlan100_ether5 0
9 ADC 10.0.192.0/24 10.0.192.254 vlan200_ether5 0
10 ADC F.G.H.165/32 A.B.C.14 PPPoE-TelekomDSL 0
11 ADC 192.168.0.0/24 192.168.0.254 ether2_homenet 0
12 ADC 192.168.128.0/24 192.168.128.254 ether3_telekom 0
13 ADC 192.168.179.0/24 192.168.179.21 ether1_fritzbox 0IP address of my nmap machine is 192.168.0.119, connected to ether2_homenet.
I think I forgot to ask for
ip address print
and your nmap command is ? nmap -sT A.B.C.14 ?
It looks like you are using routing marks. Could you show us the output of
/ip route export
Are you trying to keep address space isolated (VRF) or are you trying to do rate limits (queues)? I haven’t done much with VRFs, yet.
Toby7
January 9, 2014, 5:18pm
7
nmap command is nmap -sT as you said.
/ip address print
ADDRESS NETWORK INTERFACE
0 192.168.0.254/24 192.168.0.0 ether2_homenet
1 192.168.128.254/24 192.168.128.0 ether3_telekom
2 10.0.128.254/24 10.0.128.0 vlan100_ether5
3 10.0.192.254/24 10.0.192.0 vlan200_ether5
4 D 192.168.179.21/24 192.168.179.0 ether1_fritzbox
5 D A.B.C.14/32 F.G.H.165 PPPoE-TelekomDSL
/ip route export
add check-gateway=ping distance=1
gateway=PPPoE-TelekomDSL routing-mark=WANTelekom
add distance=1 dst-address=192.168.0.0/24
gateway=ether2_homenet routing-mark=WANTelekom
add distance=1 dst-address=192.168.128.0/24 gateway=ether3_telekom routing-mark=
WANTelekom
add distance=1 gateway=192.168.179.1 routing-mark=
fromFreyPV
add check-gateway=ping distance=1 gateway=
192.168.179.1 routing-mark=fromflyingEllertGuest
add distance=1 dst-address=A.B.C.14/32 gateway=192.168.0.240 routing-mark=table_PenetrationTesting
add check-gateway=ping distance=1 gateway=192.168.0.240
add check-gateway=ping distance=5 gateway=
PPPoE-TelekomDSL
/ip route rule
add action=drop dst-address=192.168.0.0/24 src-address=10.0.128.0/24
add action=drop dst-address=192.168.128.0/24 src-address=
10.0.128.0/24
add action=drop dst-address=10.0.192.0/24 src-address=10.0.128.0/24
add dst-address=192.168.128.0/24 src-address=192.168.0.0/24 table=main
add action=drop dst-address=10.0.128.0/24 src-address=10.0.192.0/24
add action=drop dst-address=192.168.128.0/24 src-address=10.0.192.0/24
add disabled=yes dst-address=192.168.0.0/24 src-address=192.168.128.0/24
table=main
add action=drop disabled=yes dst-address=192.168.0.0/24 src-address=
10.0.192.0/24I don't know anything about VRFs so I do not use them. There are no queues!
I don’t see anything that tells me what the issue is. Are you still seeing the extra ports when you nmap your A.B.C.14 IP?
I don’t use routing-marks so it may be some side effect of that. I’m sorry but I’m out of ideas.
Toby7
January 11, 2014, 7:18pm
9
I’ll give a try again tomorrow. Normally the open ports are still visible… Hm strange if routing marks affect open firewall ports.
May there be a bug in nmap causing supposedly open ports which are invisible?
Toby7
January 12, 2014, 11:16pm
10
The namp -sT test now show a different result:
PORT STATE SERVICE
25/tcp open smtp
80/tcp open http
110/tcp open pop3
143/tcp open imap
993/tcp open imaps
Less open ports but still now explanation for them… No changes were made to routing-marks etc.
Toby7
January 14, 2014, 8:02pm
11
Another input from my side. The pppoe connection is done over a Draytek Vigor 120v2 ADSL modem. Has this device something to do with the open ports?
lambert
January 24, 2014, 10:28pm
12
nmap the internal address just for fun.
CblP
January 29, 2014, 4:21pm
13
use the force of the packet sniffer, Luke!
Wireshark is my ultimate #1 tool for digging into any kind of network trouble/question.
