Firewall Filter Rules/NAT
Hello, please tell me, I noticed, starting with firmware 6.43, that when adding the port forwarding rule in Firewall - NAT, port forwarding added on the NAT tab works without an enabling rule on the Rules Filter tab, this is new or incorrectly configured FireWall
Those. without adding rules on the Filter Rules tab for example for the RDP port, I add forwarding myself on the NAT tab to the IP I need and I calmly connect to the computer from the outside, although without the prescribed RDP port on the Filter Rules tab, it should not establish connections.
FireWall settings in the attached file
