I’ve been running into an issue where the firewall statistics output gets cut off once the total counter exceeds a terabyte in total. The output field seems to be fixed width, regardless of terminal size (ie, with a 200 column terminal, there’s a ton of extra whitespace between columns, but the Bytes field is still truncated to the same 15 columns). terse or without-paging don’t improve things.
[admin@mikrotik1] > /ip firewall filter print stats where chain=forward
CHAIN ACTION BYTES PACKETS
0 ;;; inboundIPCounter
forward accept 1 024 535 95… 1 008 762 276
1 ;;; outboundIPCounter
forward accept 134 713 079 467 652 139 841
Is there any way to get the actual complete raw counters, or do I need to (continue to) resort to clearing the counters once it wraps?
