Firewall Filter
Dear.
Good morning to everybody. My question is the following.
Some time ago I have problems with my Telephone. And I had (DoS) attacks, which has been corrected. But it seems to me that I still have something similar because from time to time my Phone System is blocked.
issue
  • Central Telephone 1 loses communication with Central Telephone 2
Solution
  • I delete all connections within IP -> Filters -> Connection
    And the communication is established again.
On the other hand I see in the same connections that there is one with the prefixes "SACd" I send a capture on it. Please, could you help me and explain why I prefix.
Thank you
Hey. Just use firewall filter with rules you want your network behave.
Dear Anumrak.
Thanks for the answer, but you could be clearer.
Apart from that I continue with the question of why I get the acronym SACd.
Atte.
To know what the SAC means it is enough to issue following command in terminal:
/ip firewall connection> print
Flags: E - expected, S - seen-reply, A - assured, C - confirmed, D - dying, F - fasttrack, s - srcnat,
d - dstnat
